Brembo cross-drilled/slotted rotors
CL 4 LYFE
1 Post
These rotors are from the GB, that red99cl2.3 set up. I placed my order on tuesday, and i got them today. The rotors are tight. I plan on installing them tomorrow, with the help of my friend. Will post pics when installed.
A-CL Post Whore w/N2O
-S namyaC-
Uh, I hate to tell you guys - but those don't look like Brembos. Of course Brembo doen't make drilled/slotted - BUT they don't make a rotor with either of those patterns. Most take the slotted Brembo and drill the holes. You can't really take the drilled and make the slots b/c there isn't room. I've never seen any Brembos that have curved slots. They all look like Rick's and these:
x100
EBC uses curved slots, but only 4 not 8.
x100
CL 4 LYFE
1 Post
Originally posted by baka_t
I get a hub puller playa and some air tools. Its gonna be a bizzach to get them off. Btw you got your car back??
-S namyaC-
I just ran across these images, and it reminded me of this - BE SURE YOUR ROTORS FACE THE PROPER WAY!!!!!
The internal vanes should rotate like so:
The external pattern should look like it's spinning in reverse, this helps prevent buildup to keep the rotors from shaking slightly:
If your vanes and outside pattern face the same way, that's fine. It's more important that the internal vanes face the proper way - this can seriously affect the rotors cooling! The pattern direction is simply a preventative measure.
CL 4 LYFE
1 Post
these are genuine brembo's. it comes in the original box, with instructions. the rotors are engraved with brembo's signature. the rotors are probably blanks, that was drilled, and slotted.
Comrade Stalin
Re: $$$?
Originally posted by LongNguyen
how much guy...for a set of Brembo cross-drilled/slotted rotors?...thanks.
Well, I dunno...
Actually the price is $185 + shipping for 2.2/2.3 rotors and pads and $185 + shipping rotors only or $230 + shipping rotors and pads for the 3.0. Rotors can be either drilled, slotted, or both...
Comrade Stalin
Re: fit for 3.0???
i have a 3.0 cl would that work on my car?
thanks. also do you ship to canada, bc?
08_UA7_Gr33k
02-11-2016 02:17 PM
