break light/turn signal prob
so i have a 97 2.2 CL. my break lamp warning light is on. the wierd thing is, when i replaced the bulbs, the old ones appeard to be fine. 1 break lamp will work, if i take the bulb out of the working side, the other side will start to work. My turned signals are also dead, my hazard lights are working just fine. If anybody's got any ideas...
yeah the bulbs work man, just as long as only 1 is in at a time, if both are in, only 1 side will light up, but both sides will work if only 1 is in (if u change which side its in) ie. the drivers side work works if thier is ONLY a bulb in the drivers sdie, and the pasenger side works only if thier is a bulb in the pasenger side
shit, i really dont want to take it to acura haha. i dont feel like payin some dude 300 bucks an hr to diagnose this. do u know if thier is another fuse box somwhere?
Saucin
well theres only two i know of engine and passenger floorboard im thinking its your wiring but hey idk maybe you can take it to like napa or advance and have them look at it
okay so i fixed the break thing, it was a bad connection on one of the feeds. Now for the turn signals. The flasher is working (i suppose since the hazard light works). Since my fuses are good, could the relay for the turn signals have gone back?
Peace, Love & Acura
you may have a bad multi-combo switch. Are you hard on your turn signal switch. You may still need to take it to ACURA. Replacing that swtch requires that you remove the steering wheel. Check it out. Good luck.
so i tested the turn signal switch with a continuity tester and that looks good. Is there a relay that switches turn signals/hazard lights that might be broken somewhere? i'm like 2 min from just calling acura and getting this outta my hands.
quanaman
01-09-2023 07:33 PM
us285126
10-02-2015 02:03 PM
ripit
09-26-2015 06:19 PM
