Brake light problem...HELP PLEASE
Old Jun 1, 2006 | 07:14 PM
knottydreed's Avatar
3rd Gear
I drive a 1999 Acura 2.3 CL and I am about to go on a trip but found out my brake lights are out (both of them). The bulbs are still good, because i checked them. Also, the brake light fuse is also good. I am soooooo stuck. Does anyone one know what the problem might be? relay? module? etc....
Old Jun 1, 2006 | 09:52 PM
CLean 3.0's Avatar
CLeanest in its CLass
did you checked the brake light switch at the brake pedal?
Old Jun 1, 2006 | 09:59 PM
ItsDave's Avatar
are your gauges lights not working as well, if so check the fuses under the hood. The small light fuse or something like that would be it.
Old Jun 1, 2006 | 11:23 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
There are fuses under the hood too
Old Jun 2, 2006 | 04:04 AM
wilp99's Avatar
does the third brake light come on (middle one) if so then your bulbs are blown. just replace them anyways. for 1.50$ you cant go wrong. and the brake light switch is good if you can get it out of park.
Old Jun 3, 2006 | 12:27 AM
duma's Avatar
Well, my break bulbs are all goods and lite up, but the indicate (middle one) still on . Lucky a friend came over. End up to be low on brake oil. so, TOP IT OFF !! !!!
Old Jun 3, 2006 | 03:17 AM
wilp99's Avatar
dogg, that made mo sense...... at all.
Old Jun 3, 2006 | 11:00 AM
SwervinCL's Avatar
Nom Nom Nom Nom
Old Jun 3, 2006 | 11:30 AM
CLean 3.0's Avatar
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
Ny1718
Sep 11, 2015 09:21 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
