blackhousing question
ok i took off the bumper, heated, painted, then im going to let it dry overnight and tommorow im going to put everything back. I read the DIY and it sais after the housing is painted to reheat it? Am i reading this correct do i just reheat the housing for what reason?
12. Finally, make sure you pre-bake them for about 8-10 minutes on 200 degrease or heat them with a heat gun. Most high temp paints will change color and release chemicals. This will make your headlamps foggy inside or make a rainbow like film inside if not preheated. This is another reason to use a flat color. It will typically turn into a semi-gloss once it’s exposed to heat. Now you're ready to seal them back up.
https://acurazine.com/forums/1g-cl-diy-faq-74/black-housing-headlights-w-front-bumper-removal-470662/
You did scrape out most of the old sealant right? You heated them up (the entire thing to loosen what's left of the old sealant) just before you apply the new sealant and put them together?
Haha, very funny.......
But if you don't put on enough sealant and end up getting condensation, don't put tin foil over the headlights with the highbeams on for 30 minutes to "cook" the condensation out...
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
