Headlight/corner light not working
My driver side headlight and corner light in the headlight are not working..
Any helpful input? I sort of doubt its just tat they're both out, so I was wondering if there was a fuse to check or what? I bought some HID's so I'm not trying to mess the HID's up because of a fuse or something stupid.
So what shooooooould I check?
gracias
gracias
there is a diagram on the top of the fuse box cover, locate the one that says right hand headlight and pull it out..if the fuse is blown the thin metal strip inside the clear plastic housing of the fuse will be seperated in two, if the fuse is good the metal strip will be all one piece from end to end. when a fuse blows the metal strip heats up and melts to prevent the accessory from doing so, in this case your headlight
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Jan 25, 2016 06:00 PM
