Best way to increase cornering
welcome to the forum
your best bet to make the CL handle decent:
-Springs (Neuspeed, Eibach)
-Struts (Koni, KYB, Tokico)
-Sway Bars
-A rear strut tower brace.
it definately will handle good for a large 2 door. be warned tho.. the power steering reservoir is on the small side, so if you plan to do autocross, it will feel like you are losing power steering.
-Sway Bars
you already have tires so get the strut bars. they really do make a difference i have dc struts in the front and back and just adding the one to the back made a difference if u put one on the lower tie bar it will make more of a difference. than get bigger rims and wheels at the same time for better cornering. bigger tires means better handling. then u should drop ur car with some real coilovers.
Originally posted by dpvistaz
i heard there's no difference between factory strut bars and aftermarket ones????
oh and how much is it to resurface the rotors??
dp
dp
i dont remember how much it costs to resurface the front rotors.
Sep 17, 2015 09:01 PM
:P
