View Poll Results: How Did You Drop Your CL??
I Used Coilovers
15.00%
I Got Drop Springs (ie: prokit)
45.00%
I've Used Another Method (ie: AirRide)
5.00%
I Havn't Lowered My CL
35.00%
Voters: 20. You may not vote on this poll
Best Way To Drop The CL???
Old Mar 19, 2003 | 11:44 AM
Acura3.0CL's Avatar
DamnThisHobby'sExpensive!
Hey, Im looking into a set of Coilovers....whats the best way to drop the CL?? Whats different from coilovers and drop springs (besides the ajustability w/ coilovers)
Which do you all like better???
Whats the Pros and Cons with Drop Springs and Coilovers??
Old Mar 19, 2003 | 02:20 PM
ib_jimmy's Avatar
I have adjustable coil-over, but i hate em! All sleave coil-overs are very bouncy, before it was aight, cuz it was worth it cuz of the look....but now that everybody bitching about how bouncy my car is, I'm thinking of going with Nuespeed Sport Springs. Coil-over suck unless you get the full coil-over which is at least $800. I would go with lowering spring rather than coil-over.
Old Mar 19, 2003 | 02:43 PM
Acura3.0CL's Avatar
would it be worth gettin coilovers if i got whole new set for only $85????? (yes their more expensive but someones selling them for cheap)
Old Mar 19, 2003 | 03:14 PM
damond's Avatar
What vehicle application would you get coilspings for a 98 3.0 ?
Old Mar 19, 2003 | 03:16 PM
suXor's Avatar
Still trolling
Jeeze, the only one with air ride that responded.
That's ok, I'll be back in a week to change my vote since I am yanking all of it out and going to a pro-kit.
Fricking air ride is awsome, but not what you want driving at over 45MPH on the roads in DFW
AIR RIDE FOR SALE
Old Mar 19, 2003 | 06:11 PM
acurastatus's Avatar
Hey listen when it comes to lowering.. what do u want... Do u want a nice ride or do u want a racey ride...
You decide...
Springs - For Nice Ride
Coilovers - Race...
Air Ride - Wouldn't recommend it...
I have eibach springs now.. but my buddy is going to get me a good deal on NEX Full Bodies...
Call me if you need a deal
Old Mar 20, 2003 | 11:18 AM
PiMpIn2.2CL's Avatar
Chris.. how much for your air-ride setup?...how many switches?...what kind are they?
Old Mar 20, 2003 | 11:20 AM
Acura3.0CL's Avatar
chris said he payed $2,000 for it 4 months ago...hes sellin it for $1,600 now...theres 6 switches, 2 main one for the front and rear and 4 for each single wheel.
Old Mar 20, 2003 | 12:05 PM
CLpower's Avatar
teh Senior Instigator
Teins, go w/ teins!!!
Old Mar 20, 2003 | 12:24 PM
Acura3.0CL's Avatar
hey...so is this a good deal / idea to get or not????
http://www.acura-cl.com/forums/showt...threadid=97945
Old Mar 20, 2003 | 01:12 PM
CLpower's Avatar
no those definately would not. I strongly suggest staying away from the sleeve coilovers (not true coilovers). True coilovers have the spring and shock incorporated w/in each other. For example, tein, nex, apex'i all make true coilovers. Those, skunk2, Ground Control, etc. make sleeve coilovers which I strong suggest not using.
Old Mar 20, 2003 | 01:29 PM
suXor's Avatar
Still trolling
chrisbpickering wrote on 03-20-2003 07:49 AM:
I paid wholesale for most of it and it is 4 months old. I paid 2000 for all the parts, but I would like to get 1600 now.
It includes:
  • 2 - 4" front cylinders
  • 2 - 3" rear cylinders
  • 8 - 1/2" Gold electric valves (each cylinder gets 1 intake and 1 exahust vavle)
  • 2 - Viair 200PSI sealed compressors (no oiling needed like other compressors)
  • 2 - Chrome 3 gallon air tanks
  • 4 - 97-99 Acura CL specific cylinder mounting brackets
  • 2 - Water traps (go inline between the compressor and tanks. Bleed them every few months)
  • 1 - custom 6 switch billet box (2 large switches for front and rear up/down, and 4 independent cylinder switches)
  • 1 - backlit LCD PSI gauge with 4 sending units (shows all 4 cylinders PSI at the same time)
  • 2 - PRessure switches (for turning compressors on and off when more air is needed for the tanks)
  • 2 - 30AMP relays for the compressors
  • 1/2" fittings and connectors
I think that is all of it. Only thing you will need need is DOT hose to connect all of it together. DOT hose in bulk is fairly inexpensive, and all the fittings/connectors are self locking with o-rings so there are no special tools needed to connect them.
Of course you need the know how and tools to work on this. You could of course have someone install it for you, but it's not that hard. If you have ever done your own springs, you can do this.
Old Mar 20, 2003 | 08:40 PM
Luckyax2's Avatar
Evolution
As Ghander Said "TEINS!!!!" There is only one thing better and that is JIC Magic. Even then you really cant tell the difference! I am buying my Tein SS from a fellow cler new for 850!! check the Black market. They are regulary like 1 G. It is 16 point adjustable plus ride height! They are the ultimate Coil over
Usmcgrunt47
Oct 13, 2023 09:35 PM
emailnatec
29
Sep 28, 2018 04:27 PM
bluetl04
Aug 16, 2016 02:49 PM
us285126
Oct 2, 2015 02:03 PM
4drviper
Sep 23, 2015 07:42 PM
