best camber kit
i got the same drop and everyone told me to get ingalls camber kit. i need one really bad, but why do they have to be so expensive?!? I'm considering just buying the prokit because its cheaper that a camberkit and i don't think you really need a camber kit with a 1.5" drop. But i'm not sure, the CL looks so much better really low!
this is the best kit for our car - in my opinion (pricey though)
Front Left camber kit (p#35720) 1.25 to +3 degrees Polyurethane Bushing MSRP = 122.38
Front Right camber kit (p#35720) 1.25 to +3 degrees Polyurethane Bushing MSRP = 122.38
Rear Left Upper Control Arm kit (P#38811) -2 + 3 degrees Polyurethane Busing MSRP = 173.66
Rear Right Upper Control Arm kit (P#38812) -2 + 3 degrees Polyurethane Busing MSRP = 173.66
Additional piece which looks like just a longer bolt with 3 washers is p#38930 and supposedly will increase the camber to + 3/4 degree in the front MSRP 14.65/each (total of 2 kits needed for front end)
*this is for the cl that is lowered to the extreme (excess of 2 inch drop* They do make the kit for not so dropped ride - but i dont have the p#'s for that - total MSRP $606.63 However - gmpperformance.com has the entire setup for $442.16 Thats the first place i have shopped/looked so far
*Let me know if anyone can get the kits for cheaper - please!!
This was taken from one of my earlier posts - i got the rear upper control arm replacement kit and installed it - I LOVE IT! I got the rubber bushing as the polyeutehane kit squeaks like mad from what i hear - I just need to get the front now... BTW: i got the hookup on my parts i paid 200.00/total for both rear, right and rear left arms. Install took 15 mintues per side too
dam that is way too expensive for a kit i got my sprint off of ebay for 150 i think but my front end of my car bounces after i had it put on but ask any one else how there car rides with a sprint front/rear kit
damn i cant sepnd 450 on camber.. i need shox 2.. if i had to spend 450 on camber i would bag my car.. ;P if the sprint kit works i'd get it... but if it doesnt take care of the prob i wont get it.. ill look into ingalls.. thx
-shawn
-shawn
Originally, I had the Specialty Products camber kit (all four wheels) and I didnt pay that much for it either. That was the problem - unfortuantely, with cars and most other toys including electronics, you really do get what you pay for. The difference is UNREAL between the Ingalls kit and the Specialty products kit (FYI - NOPI camber kit is the Specialty kit) It was well worth the 200 for the rear Ingalls kit. If you add all the tires i went through (4 - 18 inch Sumitomo's and 2 Michelin MXV4's) that 100.00 Specialty camber kit cost me almost 1100.00 in tires!! You live and learn i guess!
i got a revo technica camber kit front & back for 130$$ thats it,, from tornactive.com,,,, screw $450 thats crazy,,,i havent recieved it yet but it should be here soon,, hopefully it works on my '99 2.3
so do u only need the camber kit for the front of the car?? (sorry i dont know much about suspensions...) i only want to spend like $100 on one too...so maybe i should get ingalls off of ebay like the one listed above?
dah...
side note: has anyone installed their wn ball joint kit? If you did, can you tell me HOW ON EARTH you got the stock ball joint off...? I went to shucks and rented the appropriate tools... and still no dice.
Originally posted by AcuraCLSJ
is the ball joint camber kit any good?
Also = somone else asked how to get the ball joint out - mine came out without too much work - just use a hammer and rag and give it a good whack on the bottom and the old one comes right out - you may want to have someone lift up on the rotor - that will take some pressure off the joint as well. Hope this helps!
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
