Bent Subframe Damage FTL
Old May 28, 2009 | 02:48 AM
Blind_Shooter's Avatar
For Life
I found out that my subframe is bent pretty bad from a previous accident before i owned the car So i took it to the body shop and was told ill be waiting at least 3-4 weeks before they can even look at it. I did however find a shop that is willing to do it now I just need to find the correct subframe. Does anybody know what subframes would work in a 97 2.2? Like if an accord subframe would work, what years and models? I searched and nobody seems to know...
Old May 28, 2009 | 05:29 PM
teh CL's Avatar
when i bent my subframe i bought one from a 94' accord & it wasnt right at all..not sure why but i ended up just buying one for a CL and there was no issues with it
Old May 28, 2009 | 05:59 PM
DaInFaMMuS1's Avatar
the CL subframe seems to be set wider than the accords. We discussed that in the latest cocoa thread, the traction bar setup that would fit the accord wouldn't fit the CL because the bolt holes where it would line up are too far out, thus i make the assumption that the CL's subframe is a bit wider.
Old May 28, 2009 | 06:46 PM
Dicorp's Avatar
But cocoa has the 3.0 chassis. and the accord traction bar is for 4 cylinder chassi models.
Old May 28, 2009 | 10:39 PM
For Life
did you buy a new or used one? how much for parts and labor if u remember?? i dont even know where to get one at right now
the reason why im not sure dainfammus is because cocoa had the 3.0 and i have a 2.2...
Old May 29, 2009 | 12:19 AM
Anhedonia's Avatar
you could always try car-parts.com
ive used them for alot of parts over the years.
Old May 29, 2009 | 03:49 AM
For Life
i tried looking on that website and i cant find anything other than a frame horn? what should i be looking for? i tried frame and frame sections...
Old May 29, 2009 | 01:48 PM
Anhedonia's Avatar
hmm good call, i dont have time to search for it now, but when i get a chance later tonight ill try and help you out.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
rhdune16
Sep 28, 2015 11:31 AM
