awesome! Brown chunky crap in my empty coolant overflow!
dunno, teching ...
overheated to stall 2mos ago, radiator was cracked. replaced with new aftermarket.
3 step radiator flush, eventually filled with new 60/40 distilled mix
drove 30miles, A/C has been lame lately ... pulled into my driveway, saw coolant dripping, fans were full-blast
popped hood, coolant was coming down the sides of the overflow reservior - took off cap, coolant was boiling over
left parked level overnight, overflow was empty. brown chunky sludgy shit in the overflow
checked oil, off the dipstick. i've had it a year and never checked it. (like a high school girl)
added a quart, filled reservior and radiator. ran it 3min, oil is between the dots and looks clean. oil cap shows sludge and no bubbles
radiator full, oil / gas looking film on top or radiator and reservior
wtf?
wtf?
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Does your car overheat or is your temp guage going up high?
haven't ran her since except the 3min to was normal then. Afraid to drive in case it overheats aren't I risking warping the head if the gasket is bad?
Bought a thermostat for thirty bucks before the dealership closed. My mechanic said bring it in Monday and for a hundred I can test and tell you if it's the head gasket.
(Mid-Atlantic)
(Mid-Atlantic)
yep, that's where i was heading, thermostat
my dad said it sounds like exhaust gas is pushing the coolant out of the motor and heating it up
wouldnt there be coolant in the oil too or just oil in the coolant?
fuck.
did that, coolant danced. big bubbles came up through and the level dropped. temp guage stayed on cold and i didnt run it long.
you guys think i ought to buy the head gasket from the dealership today so i can take it to the shop with the car on monday? i want to save the 2 days ordering time...
Originally Posted by another honda board
to check for blown head gasket - with the car cold -
remove the radiator cap - make sure the coolant is full to the top of
the neck of the radiator - crank her up - if you see the coolant
jumping - you are getting exhaust into the cooling system
Boats and Hoes!
$800 on a head gasket job (188k on motor) or $395 on a low-miles motor from attarco?
http://www.attarco.com/index.php?mai...&products_id=2
the reason there is oil in the coolant is that when the head gasket is blown oil that goes through the valvetrain seeps thourgh into the cooling chambers around the cylinders into the block. and end up in your reserve tank.
I can do the swap myself just not looking forward to it - put a motor and two trannies in my db1 teg. 40k attarco with 6mo warranty sounds good, my new radiator and aem sri won't be wasted. H22 sounds even better but 1500 and I don't know what's involved...
Boats and Hoes!
Well if you can handle swapping an engine you sure as shit should be able to R&R the headgasket, just do it yourself if your lookin to spend the least amount of money. At 188k your engine's just gettin broken in :wink:
ya I could r&r I'm worried about the previous overheat though and the chances I'd have to have it machined. Never had anything done can I just walk my head into a shop or do they deal with mechanics only? That felt like a stupid question.
Boats and Hoes!
Chances are if you get your head resurfaced and replace the gasket and torque down the bolts to the correct specs it will be runnin great again so long as your valvesprings are ok.
Boats and Hoes!
yeah you're belt should be due for the second change any time soon.
It all comes down to what's the most cost effective, so maybe a swap would be, plus you can always sell the old motor or part it out for some $$
think i'll go check the place out monday, I bought an AT there a few years back and it was legit. Never done a clutch, good time yeah? What to look for guys?
thx for the tips in this thread too I appreciate all of your input
oh shit - the f22a came 94-97, don't i have to get a '97 or newer to be legit in cali on this swap??!?!?
Accord DX/LX (94-97) / Acura CL 2.2 1997 Used JDM engine imported directly from Japan. Engine has been cleaned and tested for compression, oil pressure, and leak down tested. 6 Month warranty on long block only. Warranty does not include coverage of external accessories (manifolds, distributor, timing belt, etc.) Shipping is available for $90-300, depending on destination. Shipping cost depends on location (business or residence), if you need liftgate service, or pick up from the freight terminal in your area. When ordering, please include if the item is to be delivered to a residence or business, and if you need liftgate service in order to unload the engine off the truck. Please include your phone number in your shipping information. We have been a direct importer of Japanese engines for over 24 years, with 2 stores in California. You can shop with us directly in one of our 2 locations in California, on our website attarco dot com, or here on EBay. Please check with us for all of your engine and transmission needs. WARRANTY: All of our products come with a Six month unlimited mile warranty on start up and block and head. Warranty is voided if engine is overheated or mistreated. The warranty does not cover any external parts such as, Alternators, Starters, Distributors, Wiring, Belts, sensors, gaskets, plastic trim, and wire harness. There is no warranty on broken plugs or sensors as these often get damaged durning the shipment from Japan to US. In case of any warranty claim we will replace a defective item by shipping a replacement engine, but the customer will have to pay for the shipping of the defective item back to us.
Old School Ridin Clean
dunno, teching ...
wtf?
wtf?
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
