Automatic Transmission: fix or replace?
Old Apr 30, 2006 | 12:54 PM
  #41
Slooo97CL's Avatar
Originally Posted by Michael Wan
Hey,
If it isn't too late, I discovered this site:
http://www.phoenixhardparts.com/inde...ROD&ProdID=243
Many people with domestic vehicles have had good luck with them.
They want $1510 shipped for a remanufactured transmission for your CL.
There is a $550 ? core charge that is refundable.
So add in 6 hrs labor...and you should be good for about $2000-$2100.
Hope this helps,
Mike
the company is also on ebay the name is "phoenix-remanufactured-transmissions"
they have the 3.0L tranny $1095.00 buy now with $260.00 shipping
http://cgi.ebay.com/ebaymotors/98-02...60636541QQrdZ1
and the 2.2L tranny for $825.00 buy now with $260.00 shipping
http://cgi.ebay.com/ebaymotors/90-97...60636480QQrdZ1
Old Apr 30, 2006 | 12:58 PM
  #42
SodaLuvr's Avatar
No, those aren't the correct transmissions.
The transmissions you listed are for the older Accords.
The 3.0CL takes the M7ZA transmission, which is only avaliable at this link:
Old May 1, 2006 | 09:16 AM
  #43
Gaujo's Avatar
hey thanks alot for the help guys. I appreciate the links and info!
I found a local trans shop and the guy says he'll rebulid + change solanoids + new TC for about $1,500 so I think I'll go with him since he has the same 12k mile / 1 year warranty as everyone else, same parts and is cheaper. Also I checked the better business beuro and they have a clean record. Any reason this doesn't sound like the right plan?
Old May 1, 2006 | 05:02 PM
  #44
SodaLuvr's Avatar
Sounds great....but that's awfully cheap for a rebuild, solenoids, and TC....really suspicious. Parts could easily run you near $1000.
You might want to check w/him as to what he considers a rebuild. At a minimum, rebuilds should contain the following:
1) All new filters
2) New Seals/Gaskets
3) Sealing Rings
4) Pistons
5) Steels
6) Friction Plates
Replaced as needed:
1) Bushings/Bearings
2) Gears
3) Clutches
4) Valve Body
5) Torque Converter
7) etc....
Mike
Old May 1, 2006 | 05:43 PM
  #45
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Originally Posted by Gaujo
why can't u pass emissions?
PS can u pass an inspection with busted airbags?
Old May 5, 2006 | 01:02 PM
  #46
Gaujo's Avatar
OK well I ended up getting the transmission rebuilt by a local guy and it costed $1,800 total. He replaced all the solanoids, the Torque converter, rebuilt it, and replaced about $350 of hard parts. It is shifting much better, but it still seems like its not really smooth into 2nd gear. Is this how yours are too? He said it will have a break in period of 500 miles where it continues to get smoother.
Old May 5, 2006 | 01:15 PM
  #47
ajtcl's Avatar
Peace, Love & Acura
Mine shifted smoothly off the bat, but yeah on the break in, just be a granny for a month or so... I didn't start doing anything rough with mine untill I had a good 1000 miles on it. But now, I gate in traffic and romp on it now and then. Still nice and smooth.
Old May 5, 2006 | 02:55 PM
  #48
Slooo97CL's Avatar
hopefully you got some sort of warranty
Old May 5, 2006 | 03:20 PM
  #49
Gaujo's Avatar
hell yea 12k / 1yr
Old May 5, 2006 | 05:22 PM
  #50
Slooo97CL's Avatar
hell yea 12k / 1yr
niceeeeeeeeeeeeeeeeeee
Old May 5, 2006 | 11:58 PM
  #51
SodaLuvr's Avatar
The transmission may need some time to break-in, but its possible that you've trained the ECU to hold the gears longer through aggressive driving. You can usually reset the adaptive properties by removing the battery cables overnight, if desired.
Otherwise, I would look for the fluid as the cause. Many rebuilders tend to add Lubegard Black to Dex III ATF for use in Hondas, which is fine if changed frequently. However, Hondas do tend to shift a bit harder so they may need a bit more than the usual 1oz/qt dosage to obtain smooth shifting. I've heard that 1.25-1.5 oz/qt is sometimes necessary to achieve smooth shifting.
Old Nov 19, 2013 | 01:30 PM
  #52
toddnoeth's Avatar
5th Gear
i realize this is an old strand... but i asume that many here are still members. i just joined today trying to find some help with my 1998 3.0 CL. i lost reverse. just grinds and wont ingauge. i talked to a local shop here... very reputable shop here. and they told me i need a new shift fork, reverse gear and hub. total cost with labor is 1800... i'd like to do the work myself... but i'm not positive on exactly what parts i need to order... can anyone send me a diagram detail in internal parts??? thank you all.
Old Nov 19, 2013 | 02:15 PM
  #53
cobra10363
Jul 23, 2024 04:13 PM
spidermankb
Mar 5, 2019 11:34 AM
gqdabien
Sep 8, 2015 11:41 PM
yahelou
Sep 6, 2015 09:12 PM
NSolace
Sep 3, 2015 08:02 PM
