Anyone ever have an engine code 22 (vtec malfunction)?
Old Jan 28, 2003 | 08:57 AM
AtlCl's Avatar
Not AtlCl98 or Atl-CL
Check engine light came on yeasterday, so I did the paper clip thing to check the code and it came out as 22. I looked it up in the manual and it said that it was a "vtec system malfunction". Anyone ever have this?
Old Jan 28, 2003 | 10:03 AM
KC CL 1785's Avatar
cmng 2 a lawschool near u
ummm ,no. Maybe you should head down to the dealership, seems pretty imporatant. A word of advice, don' go into v-tec range.
Old Jan 28, 2003 | 10:13 AM
23's Avatar
23
I had that when I was hooking up my VAFC but I reset the ecu and it took care of the problem
Old Jan 28, 2003 | 10:14 AM
AtlCl's Avatar
Car seems to run fine though. Haven't really run it hard since the light came on. Scared to test the vtec.
Old Jan 28, 2003 | 04:25 PM
AtlCl's Avatar
Upon further research I found that this code applies to either the VTEC pressure switch of solenoid. The dealer said that I am probably really low on oil. So I checked the oil and I was low. But after adding 2 quarts the light has not gone off.
Old Jan 28, 2003 | 06:36 PM
VXCL's Avatar
AWD Torque Monster
it wont the ecu has to be cleared with an obdII scanner. even disconnecting ur battery for a day will do nothing. i think it depends on the code. i dont think certain ones can be cleared without a scanner. i had my light on once for something and no matter what it would not go away until i hooked a scanner up and cleared it
Old Jan 28, 2003 | 07:39 PM
niedejb's Avatar
Swaps? $3000 for 50HP? :(
Try pulling the 7.5 amp fuse under the hood now that you added the oil. (get your radio code if first if you have a stock head unit).
This will reset your ecu.
Old Jan 29, 2003 | 08:38 AM
AtlCl's Avatar
Thanks, I'll try that during lunch. Sucks to have to reprogram the headunit all over again.
Old Jan 30, 2003 | 10:40 AM
AtlCl's Avatar
pulled the 15a and 7.5a fuses and the light reset itself. Problem solved
Old Jan 30, 2003 | 05:15 PM
niedejb's Avatar
Problem solved
Wouldnt be that quick to judge. It may come back.
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
ghuns
Sep 16, 2015 04:26 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
Desert Ridge
Sep 5, 2015 09:47 AM
