Amp problem
Old Feb 14, 2008 | 10:03 PM
tman89544's Avatar
Amp problem
About a week ago i had a new fuse put in my car after it was either blown out by my brother or the shop that did work on it (my car was in the shop while i was at college). Well anyway, after getting my new fuse in my sub was working basically fine. Then after playing it for like 10 minutes it started to smoke and ever since then the light on the sub hasn't gone on and the sub has been fucked. I looked at the fuse but it is fine. Does anyone possibly have any idea what went wrong?
BTW i have a JL amp.
Old Feb 14, 2008 | 10:11 PM
AznX TL's Avatar
where is....
amp is toast.
Old Feb 15, 2008 | 08:26 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
I don't see how a fuse would have anything to do with it unless it's wired wrong
Old Feb 15, 2008 | 11:28 AM
tman89544's Avatar
Well last night for some reason it started to work. Once i turned the volume up louder it just shut off. I've got it turned to 250 so i dont know why its doing that.
Old Feb 15, 2008 | 12:14 PM
(Mid-Atlantic)
get a cap
Old Feb 15, 2008 | 12:20 PM
tman89544's Avatar
No idea what a cap is.
Old Feb 15, 2008 | 12:29 PM
Vidman213's Avatar
cap = capacitor. It basically protects the amp from getting too much current, for example your amp might be getting fried because it is getting too much current, a cap would remedy that
Old Feb 15, 2008 | 12:39 PM
tman89544's Avatar
Uhh you mean like a converter? I've got one of those.
Old Feb 15, 2008 | 01:49 PM
young03's Avatar
its JDM yo!!!!!!!!
it sounds like there is too much current going to ur amp causing it to act funny. also make sure that its the right amp fuse in ur amp.
Old Feb 15, 2008 | 02:04 PM
wonton's Avatar
sounds like your amp is fried. first the smoke comming out of the amp is definitely not a good sign and if it does not light means that its blown out. Check to see if your getting power through the wires.
Old Feb 15, 2008 | 02:51 PM
aqua1stgen's Avatar
hmm...
1: check wires and all connections
2: be sure that you're using the right fuse(s)
3: might possibly be able to take it to a shop to get it checked out
4: new amp =(
Old Feb 15, 2008 | 02:55 PM
young03's Avatar
its JDM yo!!!!!!!!
4: new amp =(
forget that just get a new amp. is ur amp new and if it is see if the warranty can possibly do something.
Old Feb 15, 2008 | 03:01 PM
Vidman213's Avatar
JL is weird I think their lifetime warranty only applies if the equipment is installed by a authorized JL dealer, could be mistaken though.
Old Feb 15, 2008 | 03:06 PM
tman89544's Avatar
The amp is a 2 year old JL amp. I got it from a good friend so i know he didn't fuck with it.
Today it was playing well at low volume, but when i turned it up it just stopped hitting. as far as i know all of my fuses are good and my wires are all plugged in. Here are pics of what may be wrong (sorry about poor quality)
All the help is appreciated.
Ill probably have more pics up later to see if anyone sees anything wrong.
Old Feb 15, 2008 | 03:26 PM
(Mid-Atlantic)
Check your ground
Old Feb 15, 2008 | 03:47 PM
young03's Avatar
its JDM yo!!!!!!!!
u might also want to check ur charging system to make sure all is well
Old Feb 15, 2008 | 07:16 PM
tman89544's Avatar
..And where would the charging system be? I really need to get a booklet or something that can help me with this. I bought these used and with no instruction manuals.
Old Feb 15, 2008 | 08:08 PM
1V4N's Avatar
1st Gen CL Noob
charging system?? That basically means looking into your alternator and the rest of the electrical setup...
Old Feb 15, 2008 | 08:17 PM
(Mid-Atlantic)
charging system is your alternator, you can get that tested, but I doubt that's the prob.
Check the ground to the amp, ground points are hard to come by in our trunks, took me 4 dif places b4 I found a good one.
Old Feb 16, 2008 | 01:25 AM
implicit's Avatar
eh
Exactly - sounds like you're just pushing the amp too hard.
You might have the wrong impediance sub for that amp or its been played too loud for too long.
Most amps have a fail safe and turn off when something's wrong. Usually turning it off and on will reset it. Sounds like you're tripping the breaker.
You can:
replace the amp
or
keep the volume down so the amp doesn't cut out
Old Feb 16, 2008 | 11:09 AM
(Mid-Atlantic)
Or turn the gain down, but if your amp was smoking it's already toast
Old Feb 16, 2008 | 02:36 PM
tman89544's Avatar
The thing is, when it was first smoking i wasn't blasting it that loud. It played well for a day or two after i put my new fuse in then it just went to shit.
Old Feb 16, 2008 | 03:02 PM
(Mid-Atlantic)
Did you put the fuse in the amp or the car fuse box?
Old Feb 16, 2008 | 04:23 PM
tman89544's Avatar
I put the new fuse in the amp wire part by the battery. Its definitley not the car fuse box.
I've been playing around(not in a bad way) with the nobs on my amp to see if maybe something was messed up back there but ive had no luck.
Old Feb 16, 2008 | 08:00 PM
(Mid-Atlantic)
is the new fuse blown?
Old Feb 16, 2008 | 09:31 PM
tman89544's Avatar
The new fuse is fine. I may have to just pay 25 bucks to get it looked at.
Ontop of all this i got a flat tire last night and my donut is low on air. Fuck.
Old Feb 16, 2008 | 09:49 PM
(Mid-Atlantic)
Sux man, the problems come in threes
Old Feb 16, 2008 | 10:14 PM
tman89544's Avatar
Yeah, i actually had MORE tranny work done about a month ago. Of all things i saw someone blow out a tire on the exact same spot where i blew mine.
I can probably fix all of this shit up its just going to cost me alot of money.
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
