alignment problem???
Old May 16, 2002 | 11:04 PM
sonicdigital's Avatar
guys, i have been noticing abnormal in my steering wheel, when i turn left the steering will doesn't fully pull back to the center position, i have to manually turn about 1.5 inch for it to be back in center position. but when i turn right, it fully pulled back to the center.... and also, when i brake to a completely stop. the brake pedal vibrate like hell, and it also pull my steering wheel to the left. ABS always kick in like that? Any clue guys???
Old May 16, 2002 | 11:12 PM
PoPlaya's Avatar
steady gruuvin'
could be that your tires aren't aligned right....when i lowered my shit, my alignment was set to the right....so i had to go and get it fixed....i dunno about the break shit though....
Old May 16, 2002 | 11:34 PM
So did you have to manually turn it back to center? or was it just misaligned? the thing is if it was alignment problem then my car would go straight if my steering wheel was to the left but it will still going toward the left unless I centered it....
and the abs shit is weirddd.
Old May 17, 2002 | 12:47 AM
PoPlaya's Avatar
steady gruuvin'
if your tires aren't aligned right, your steering wheel will either pull to one side, or won't go back all the way.mine still does it a little bit...and your car wouldn't go straight if it the steering whell was left and if would go left if it was centered....it depends.....if you got a les schwab around your area, go to them and ask them.....they'll know...
Old May 17, 2002 | 01:10 AM
gjr2001's Avatar
An Official Cl Whore
Check your rotors, you would be surprised.
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
