ac question
Old Jul 2, 2006 | 09:35 PM
Shaggz2Dope's Avatar
2.2 auto and coping
ac question
how come the whole ac unit is working while my car is off
Old Jul 2, 2006 | 10:23 PM
SupraManAG's Avatar
One custom CL
off like how?
ac unit should go on when the car is off and key is the first position
the a/c will work on the second key position. even though you think the a/c is on, the compressor isn't on because the car isnt on for the belts to move. therefore you are blowing air.
Old Jul 2, 2006 | 10:40 PM
2.2 auto and coping
ok. is hard to explained the key is not on the ignition
the display is on 67 degree but theirs not cold air coming out, .
and the compressor is off
Old Jul 2, 2006 | 10:44 PM
SupraManAG's Avatar
One custom CL
u really need to rewrite that
i dont understand what ur trying to say
Old Jul 2, 2006 | 10:46 PM
GnarleyMarley87's Avatar
98 2.3CL
i think he's saying that he's auto climate display is still on whilst he's key is out of the ignition and the car is off, no?
Old Jul 2, 2006 | 10:50 PM
2.2 auto and coping
ok the car is off no key just off . when i went to check my car the climate control was on
Old Jul 2, 2006 | 10:51 PM
SupraManAG's Avatar
One custom CL
weird. the thing is on with no key in the ignition
anyways
what do you care. just turn it off
Old Jul 2, 2006 | 10:52 PM
2.2 auto and coping
ok
Old Jul 2, 2006 | 10:59 PM
2.2 auto and coping
i did. but 15 minutes later it was on again.
well now the alternator is making a noise
Old Jul 3, 2006 | 09:42 PM
2.2 auto and coping
my bad..... my girl wrote this while i was at work....
the prob was.... i parked my car....took out the keys...left....came back 15mins later....
the climate control, ac was on...no cold air, but the fans..... and the temp said 67 when i left it on 80
i can turn it off and on while the keys are not in the ignition,,,
its not supposed to be on.....till the keys are in.....
i put them in and turned it to on II position, (accesories) then off, and it was still on.
turned on the car....then off.... and the fans and display stayed off. i changed the temp to 75
came back 30 mins later and its on again..... I turned on the car... and it slowly began to stall...i gave it a lil gas...it stalled.
I started it again...and i got a loud sqwealing noise.... either from the altonator or the starter...... it kinda sounded like if you crank it after the car is started...
i jiggled the igniton cause i thougt that was the prob....
reset the engine..... started fine no problems..... an hour later...cc on again...
Old Jul 3, 2006 | 10:12 PM
SupraManAG's Avatar
One custom CL
you def have a short somewhere
sounds like a grounding issue
that is very weird though
you car might just be haunted
Old Jul 5, 2006 | 09:12 PM
2.2 auto and coping
i gots da spooks...
a thing i forgot to mention..... it was raining real hard.....drove through some puddles and after i parked it...that sh!t happened.
now i gots no cold air comin out my ac.....
Old Jul 5, 2006 | 09:35 PM
SupraManAG's Avatar
One custom CL
lmao
well why didnt u say that from the beggining
try a simple test
start your car
open the hood and have your gf in the car
have her turn on the ac
you should be able to hear the conpressor working and should immediately see the fans working
if that does not happen you need to get a electrical guy to find out which wire is busted
i had the same problem with my car
if the fans do start and the compressor is working then you are out of freon
goodluck
Old Jul 5, 2006 | 09:56 PM
2.2 auto and coping
fans work...but dont know bout the compressor..... i think it does.... cant hear it well....
Old Jul 5, 2006 | 10:02 PM
SupraManAG's Avatar
One custom CL
the fans start once u hit the ac button?
Old Jul 5, 2006 | 10:07 PM
2.2 auto and coping
yeah
Old Jul 5, 2006 | 10:19 PM
SupraManAG's Avatar
One custom CL
check if the compressor is working
if it is then u have no freon
but 2 cans and fill it
Old Jul 5, 2006 | 10:35 PM
2.2 auto and coping
ima check ina minute.... can i feel it come on?
Old Jul 5, 2006 | 10:47 PM
5-speed's Avatar
4x4- fat chicks cant jump
your rpms will drop a little if youve got a 2.x, i dunno about 3.0s. is that what you meant by feel it?
Old Jul 5, 2006 | 10:48 PM
2.2 auto and coping
yeah it does that^.........guess its freon....... ill hit up azone tomorra
Old Jul 5, 2006 | 11:45 PM
SupraManAG's Avatar
One custom CL
you need to buy the recharging kit
have the unit hooked up to the line
connect the freon can
start the ac and open the valve
let the car run till the can is completely empty
cheers
Old Jul 6, 2006 | 08:07 PM
2.2 auto and coping
alright...... i got the recharge kit.... checked the psi.. 40....
but before i use it..... i dont think the compressor comes on..... just the fans..... the rpms dont fall...they rise a bit.... when i put the cc on auto 90...the rpms fall cause the heater comes on....
the same doesnt happen when the ac is supposed to be on....
the instructions say that if the compressor doesnt come on......to use one can (it came with two) this one
but the psi is at 40....sooo....
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
