AC problem help!
Old Jul 11, 2005 | 02:52 PM
christopher g's Avatar
AC problem help!
I have one problem with my car that I cannot seem to figure out, when ever the AC is on and the extra load is placed on the engine when I depress the clutch the revs drop to about 700 - 750 RPM and the car shakes then the idle slightly climbs once it settles. I have done all my maintenance on the car including plugs and wires. The engine is a 2.3 single overhead cam. This happens when slowing down to stop at a light or basically anythime i depress the clutch, it makes the car very difficult to drive with the AC on.
What can i do to fix this?
Old Jul 11, 2005 | 02:55 PM
zoltanh's Avatar
I need a Hybrid CL-S
This happend in my 1994 mitsubishi galant when i had it. The problem was the throttle position sensor and/or idle control motor/valve. Those are like $150+ dollar parts though. Maybe take it to an auto store and have them hook up a computer to it to see if it is giving you any codes.
Old Jul 11, 2005 | 04:12 PM
wilp99's Avatar
could be a vaccume leak.. check all hoses for cracks. and make sure the iac idle air control valve. is not clogged.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
