5 speed shifter question
Okay, dumb question:
Why would the shifter start to feel loose? Kind of wiggly. Plus it can move into neutral without engaging the clutch (not on its own, but with a little force). What is wrong? What can I do? Is the clutch going?
98 2.3
98 2.3
Master Newbie
Re: 5 speed shifter question
98 2.3
98 2.3
About moving it from gear to neutral with out engaging the clutch. That's also normal. If you were to time it just right you can actually shift a manual transmission with out engaging the clutch. I've never done it in my CL, however I have done it many times in my Escort GT. The key is to not force it. I also do not recommend doing this, as the potential for grinding gears is always a really bad thing!!!
09-14-2015 10:48 AM
