4 gauage wire?
Old 09-25-2002, 08:58 PM
ENGAGE MY VTEC BABY!!!!!!
97Acura3.0CL's Avatar
4 gauage wire?
how much 4 gauage wire should i need for my alternator? and what else do i need? the place told me to get 4 gauage and hook it up to the power terminal to the battery to get the juice for it. dust you said you can use the stock wire? can u and will it work the same as if you used the 4 gauge? let me know what i need so i can go get and install this thing and get my tunes back and working again.
Old 09-25-2002, 09:09 PM
Swaps? $3000 for 50HP? :(
niedejb's Avatar
Use the stock wire. Dont need 4 gauge for that short of a run.
Old 09-25-2002, 09:57 PM
but why? why do they say to change it to 4 gauage?
Old 09-25-2002, 10:14 PM
A-CL Post Whore w/N2O
dustbuster4's Avatar
Not sure why? The stock wire works just fine.
Old 09-25-2002, 11:02 PM
A-CL Member
curtrahmel's Avatar
I put in an 180amp alternator and it works fine with stock wiring. They probably didn't know that the stock alternator is 105amps and that it is already wires with 4gauge wire.
Old 09-26-2002, 11:58 AM
Turn Signals are good!
SumkidwithaCL's Avatar
sorry to sound like a dick, the stock alternator is 90 amps... and the stock wirring is 8 gauge.
The alternator does not need a heavy wire, A: its a short cable run like niedejb said and B: all the alternator does really is keep the battery charged.
Old 09-26-2002, 12:32 PM
CO30CL's Avatar
Why you guys upping your alternators? Are you having problems w/ battery draining? I have AEM underdrive pulleys and two amps for stereo, and see no problem running stock alt. Also, where you get 180amp one and how much? Thx.
Old 09-26-2002, 01:25 PM
I was getting dimming of the dash lights when the cooling fan kicked on (this is with 1400 watt amp, head lights, fog lights, AC, running at the same time).
I got mine from eBay: http://cgi.ebay.com/ebaymotors/ws/eB...tem=1860106891
BTW: I got mine for $149.00.
Old 09-27-2002, 06:15 AM
A-CL Member
curtrahmel's Avatar
97Acura3.0CL , have u tried a cap or a deep cycle or marine battery. I had thet similar problem pushin 1 jl audio 1000/3 and 1 600/4 and the marine battery and cap worked. I just got the alternator for future expansion.
Old 09-27-2002, 09:37 AM
CO30CL's Avatar
Is this something easy to install yourself? I didn't look, but are the bolts and stuff accessable?
Acura604
20
08-05-2017 12:55 AM
ITSJESTER
4G TL Photograph Gallery
10-13-2015 12:53 PM
MilanoRedDashR
10-08-2015 10:30 AM
SUPRMN84
10-07-2015 09:46 PM
27trains
4G TL Problems & Fixes
09-30-2015 09:44 AM
Quick Reply: 4 gauage wire?
