3.0CL engine Mods ?
Old Jul 18, 2004 | 06:11 PM
4you2nv's Avatar
3.0CL engine Mods ?
Whats up Guys and you lovely Lovely Ladies out there. I have a question to ask what kinda of engine mods are there for the 3.0CL platform. I know of headers custom turbos and comptech's supercharger but they are not in my opinon worth the amount of money that needs to be invested. Yeah there all cool and all but 4000k on a supercharger the only adds 50 to 60 horsepower sucks. There has got to be some peeps out there who have some tuning tricks that would help. Also I would like to know f the NSX 3.0 engine shares the same parts if so could there heads be used better flowing I'm assuming. I done a couple of things already cold air intake less restrictive Catalytic Converter and a Custom Cat back Dual Exhast the lools factory will post pictures latter. And last how do the grounding kits seem to work as far as being worth the investment. Thanks Joe
Old Jul 18, 2004 | 07:01 PM
white3.0's Avatar
I doubt that the NSX engine and the J30A1 have anything in common other then the name Acura. From what i understand the NSX is a V6 DOHC motor thats mounted behind the car. with that being said the engine bay would be totaly different, and things made to work and fit in the NSX engine bay would be totaly different then the 3.0 CL? just my guess
Old Jul 18, 2004 | 09:44 PM
baka_t's Avatar
The movement has started
Buy a comptech supercharger.
Old Jul 18, 2004 | 10:17 PM
4you2nv's Avatar
repley to white 3.0
the engine bay wouldn't have anything to do with the stock internals the wiring yes would be different and some things would be different on the nsx. But my real question is the nsx 3.0 and cl 3.0 share the same bore and stroke and same physical characteristics. I Used to work in a Machine shop building race engines so i guess the main thing is does anyone truly know what the differences are between these motors? And Baka T as far as the superchatrger maybe you should read above about my opinion on them it seems all the guys who have them get rid of them does't that tell you something.
Old Jul 18, 2004 | 10:44 PM
white3.0's Avatar
I doubt swapping there heads would be possible or beneficial being that they are DOHC and we are SOHC
Old Jul 19, 2004 | 05:30 AM
ju5tchi11in's Avatar
roomate has a CL too
Go look up the engine specs of the 2 engines... nothing the same about them... except displacement?
find a pic of the engine bays of the 2 cars totally different not much fits.
SOHC and DOHC there is your main difference.
get some headers an intake an exhaust a throttle body spacer a ZEX wet 100 shot tranny cooler new plugs wires fuel pump VAFC II some unorthodox racing pulleys CL-S machined cams.
and an E TURBO!!!!!
j/k
but yeah those other things should set you up well.
Old Jul 19, 2004 | 07:00 PM
Hobo's Avatar
Flap.
uh.... dont waste your money and go straight to the nitrous thats the only real power to be gained aside from headers... and hop on that tranny cooler.
Old Jul 20, 2004 | 11:01 AM
CO30CL's Avatar
Indeed. The Comptech SC with the high-boost (8psi) pulley is awesome. Be sure to get tranny cooler, headers & exhaust to go along with it though.
oo7spy
Jun 19, 2023 12:48 AM
Yikes
May 3, 2021 04:29 PM
BoricuaTL
Apr 8, 2016 01:08 PM
sockr1
Oct 1, 2015 01:31 AM
oyayjoe
Sep 12, 2015 04:40 PM
