1997 CL 3.0 ABS light
Old Nov 24, 2012 | 02:10 PM
1997-CL-3.0's Avatar
The light comes on several seconds after starting the engine.
I just bought this car...only 57,000 miles. The previous owner said the light came on after the front brakes were changed.
A couple friends said to disconnect the battery for ten minutes...didn't help.
I pulled each wheel off and the LEFT wheel outside CV joint boot leaked a lot of grease on the sprocket-like wheel for the speed sensor and on the speed sensor itself. The metal band on the boot isn't tight enough. I used brake cleaner to get as much grease off as possible but haven't had time to do more than that.
I also tested the brakes by braking hard and just before stopping, the RIGHT front tire locks up both times that I did it.
I've also been reading here about the o-ring in the abs pump.
Any clues from what I've seen so far? Thanks, Ron
Old Nov 25, 2012 | 06:53 PM
fabrizzio71's Avatar
From the ABS issues I had and from what you describe, my guess would be that the speed sensor is bad.
Old Nov 26, 2012 | 11:24 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
^ I agree it's almost always a wheel speed sensor, I've replaced 3 of mine, and the other one is bad now
Old Nov 27, 2012 | 05:31 PM
Without having a tester, is there anyway I can tell what speed sensor is bad? My only clue was the right front wheel locking up right before the car stopped.
Old Nov 29, 2012 | 07:56 PM
cl-baller201's Avatar
2.2CL owner
what is the price of this fix ?
Old Nov 30, 2012 | 08:45 AM
(Mid-Atlantic)
You will have to have someone pull the code for you, I've been putting off doing it for a year or 2, but I don't drive my CL that much
Old Feb 16, 2013 | 02:03 PM
Here's an update...l used a paper clip to short the blue connector under the dash and got a DTC code of "1". That sent me to the modulator where I found it had no break fluid.
I added brake fluid and now the ABS comes on immediately and stays on where before it could come on for a few seconds, then off for say 15 seconds then on again.
Sound familiar to anyone?
Old Feb 20, 2013 | 10:03 AM
Update...the steady ABS light was caused by me putting the ABS 15A fuse into an unused slot when I was resetting power to try to clear the fault.
Old Feb 24, 2013 | 01:53 PM
Last update....no more ABS light...looks like adding brake fluid was all it needed.
Old Apr 28, 2014 | 11:11 PM
TampaCL813's Avatar
OK. I haven't really looked into it much yet but when I start my car the abs light comes on a few seconds after. You can also hear a click from behind the glove box I believe. Any way my abs does not work. I found that out during a nice rain storm. I'm replacing my trans right now so I figured I might as well fix what I can afford to fix right now. Any ideas? Maybe a relay? That's what I thought the click may be
Old Apr 30, 2014 | 09:14 AM
(Mid-Atlantic)
It's almost always a WSS. Another thing that can trigger it is if your brake fluid is even the slightest bit low
mada51589
Jan 9, 2025 04:40 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
Stu2414
Aug 30, 2015 07:30 PM
