1997 CL 2.2 5 spd
1997 CL 2.2 5 spd
Hey guys , new to acuras . I just picked up a 1997 with 180k on it. I noticed the radiator has some green crust forming along the top of the radiator. Have any of you replaced the radiator in your vehicles? Or maybe this is normal? I also have the ABS light on , the guy I bought it from said hes been driving like this for the past five years but said he would have to top off the brake fluid every so often... Im not seeing any leaks as of yet , are the ABS pumps on these a pain to replace ? Anything else I should be aware of on these guys?
TIA
Nick
TIA
Nick
Thanks for the complement Calends and thanks for the honesty on not working on your car. Do you recall what what you paid for the new radiator? Do you still have your 98 ? If so , have you had to have any other repairs done to it?
Thanks Calends
Nick
Thanks Calends
Nick
You won't get too many replies since this part of the forum has pretty much died and the car is really old. Still some lurkers but you will be lucky to get an answer the same day much less same week.,
Ive owned my 98 for 11 years now and i haven't had the need to replace my radiator. No leaks or anything. I have replaced the clutch, master slave cylinder, and distributor. Other than that and obvious maintenance like timing belt. No real issues with the manuals.
Also this a quote from 97BlackackCL from back in the days, He's still around. Im sure he will chime in here sooner or later.
Same thing happens with my car. Your abs pump is over running itself, meaning that either the controller module or the pump itself is going bad. Or any number of sensors can cause it to trigger. I've replaced 3 wheel speed sensors, and an axle trying to resolve the issue. The other solution is to have your controller module rebuilt by Automotive Scientific Inc. | Quality Rebuilt Automotive Electronics | Rogersville, TN for like $400 this will be my next step. Or replace the whole abs brake pump unit which is over a grand. But if the light comes on everytime you start the car, that means it's throwing a code and you can pull it from the computer, any major carparts store will pull it for you for free, like advanced or autozone. Another couple easy things to check is the positive battery terminal is not coroded, because a loss of power causes the picky abs pump to come on. Also, topping off the brake fluid.
Thanks for the replies guys I appreciate it . Asianspec , good to know and thanks a bunch . I went ahead and had the radiator replaced today , Im going to do a shake down run tomorrow on the interstate . I will check back and see if 97BlackAckCL replies to the post. If nothing maybe I can send him a PM , if thats an option here. Again , thank you very much guys for the replies , very much appreciated
Nick
Nick
I replaced my radiator years ago, it wasn't that bad honestly.
Why do you want to replace the ABS pump, is there an issue or just the light coming on?
ProjctCL07
May 25, 2016 07:55 AM
WisconsinMicko
Apr 13, 2016 02:29 PM
