Trailer Brake Controller
Thanks a bunch for the instructions, they will certainly be useful when installing the wiring, but they still don't show where to plug in the controller. The next to last page has a a picture of the pigtail (subharness) that needs to be spliced on to the controller, but doesn't tell me where to stick it! My Ford F 150 has a plug right under the steering wheel, but I can't find anything similar on the Acura. The only open jack I see is for the OBD II
Once again, thanks for the info
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
Hi, installed all up to brake controller harness....thanks for the pics!! I assume the four wires then plug into any aftermarket controller?? If so, why does etrailer.com list all their brake controllers "not for use with OEM Acura wiring harness"??? Did anyone use a product they would recommend? HELP Please! Trying to go camping on weekend!
Best regards from Montreal
Hey frenchnew, how did you pick up the power and brake controller signal for your 7 way to run your brakes? My installer says he can't see where he gets these 2 wires and only installed a flat 4 for me? Any help would be appreciated guys. Thanks
He bought and used the OEM trailer wiring harness which plugs into the MDX chassis wiring harness. (plug & play) The OEM wiring harness comes with a brake controller 4 wire pigtail that plugs right into the connector under the dash (see my post aobve with the pictrue of where under the dash the plug is hidden) This pigtail provides all the wiring needed to run the controller/brakes.
SidhuSaaB
05-30-2020 12:40 AM
navtool.com
31
11-16-2015 08:30 PM
joflewbyu2
10-08-2015 11:16 AM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
2004, 2008, 87474, accura, acura, brake, controller, controllers, electric, harness, hidden, hitches, installation, mdx, trailer
