timeing belt and water pump
105k miles
Check your owner's manual. Or if you don't have one you can find maintenance schedules on Edmunds.com or even better, register your vehicle at www.myacura.com and you can download the manual.
You will get a service reminder in your car and it usually is between 100 and 110 K miles.
My car is around 90K and I'm waiting for the reminder to pop up.
I already did the pluggs, engine oil, differential fluid, transmission fluid, cabin and engine air filters.
I am not savy enought to do the timing belt, water pump and valve adjustment.
Its a piece of cake really easy to do but I work at a honda dealer (for 30 years) and 3-4 a week it takes me about 1 1/2 hours to do plan on 5 hours at home you will need a crank pulley holding tool and a tool to hold the timing belt tensioner in it comes with a new honda or acura tensioner but not with most aftermarket ones other than that just follow the directions and make sure the timing marks are lined up and do not turn the engine or cam pulleys after belt is off you can do it yourself if you are mechanicly inclined it is easy for me but spelling is so hard and were do i put periods and capitols I think they call this a run on paragraph I will stick with fixing cars
Timing Belt video
Not sure if you've done this already but I've seen a really good how to video. I need to search for it and get back to you.
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
asahrts
Sep 4, 2015 05:55 PM
