Remote Starter from Acura
Old Feb 7, 2010 | 09:34 AM
michalm's Avatar
I have Remote Starter form Acura, and I'm little disapointment. When I start engine using Remote Starter than I can't open the door using button on my remote control car. It is not working. When I using key to open the door (regular one) engine stops. Dealer told me that this is normal. If you start engine using remote starter to get to my car I have to stop engin using remote starter and then I will be able to open the door using standard remote control car.
Somebody can confirm that this Acura remote starter is working like that...
Thank you
Mike
Old Feb 7, 2010 | 03:49 PM
KevinMR's Avatar
Wow that sounds odd...can you unlock the car first and then use the remote starter (i.e reverse the order)?
Old Feb 7, 2010 | 04:54 PM
007Acura's Avatar
That is normal, your dealer should have explained how the system works before you bought it... on the bright side they can't void your warranty with an electric related problem since it is oem.
here is a video about it...
http://www.youtube.com/watch?v=jXKjaDTQ3Ns
Old Feb 8, 2010 | 12:55 PM
michalm's Avatar
OK, Thank you ! I got it
Old Feb 18, 2010 | 10:17 PM
billman730's Avatar
Problem is it is Accura that does not "Get-It". It should be at least as handy as my $200 after market installed in my Chevy truck. Like Hold brake pedal turn and remove key while pressing start button will keep engine running so I can run into a store. Not the Acura though...
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
mazen222
Oct 27, 2015 12:01 AM
3.5RLv-tec?
1/2G MDX (2001-2013)
Sep 7, 2015 11:00 PM
dlknight
Sep 3, 2015 07:54 PM
datadr
Sep 2, 2015 06:46 PM
