Power Steering Pump O Rings
Old Sep 21, 2019 | 05:38 PM
Contsi's Avatar
2007 MDX - Are the 2 O rings the same part number?
Than you
Old Sep 21, 2019 | 09:55 PM
Skirmich's Avatar
You mean for the inlet and outlet hoses? if so then No they are different sizes.
Old Sep 21, 2019 | 11:58 PM
https://www.oemacuraparts.com/v-2007...s-pump-bracket
Old Sep 23, 2019 | 01:27 PM
Contsi's Avatar
Thanks for the quick response.
I have a high pitch whining noise which seems replacing the O rings may help.
Looks like part #s 13 & 14?
Old Sep 23, 2019 | 02:19 PM
AcuraAddicted's Avatar
13 - yes. 14 - no. The other one is not on this page. It's in "P.S. Lines"
You can check out the process and proper part numbers (in the description) in the following video:
Old Sep 24, 2019 | 04:40 PM
csmeance's Avatar
you may need to replace the internal seals rather than the 2 seals you mentioned. Gates has a kit for less than $20 and it'll take about 1hr to rebuild at home. You'll be surprised at how the old seals have flattened out!
Old Sep 26, 2019 | 04:57 PM
acuratech481's Avatar
We rebuild these at work all the time, super easy! The one that causes noise issues is usually the suction hose inlet o-ring and the hoses from the reservoir have become hard and don't seal properly allowing air to be sucked in.
feliks66
1/2G MDX (2001-2013)
Dec 5, 2018 02:06 PM
emilyb
19
Jul 25, 2016 09:18 AM
jdm_94-07TypeS
Sep 17, 2011 08:20 AM
MICKWOODLYN
Jan 20, 2010 10:53 AM
AcuraCl1
Jan 26, 2005 11:20 AM
