Power Steering Pump O Rings
2007 MDX - Are the 2 O rings the same part number?
Than you |
You mean for the inlet and outlet hoses? if so then No they are different sizes.
Thanks for the quick response.
I have a high pitch whining noise which seems replacing the O rings may help. Looks like part #s 13 & 14? |
Originally Posted by Contsi
(Post 16483349)
You can check out the process and proper part numbers (in the description) in the following video: |
you may need to replace the internal seals rather than the 2 seals you mentioned. Gates has a kit for less than $20 and it'll take about 1hr to rebuild at home. You'll be surprised at how the old seals have flattened out!
Originally Posted by csmeance
(Post 16484013)
