Noise when accelerating
Old Jan 30, 2015 | 11:55 PM
Benima's Avatar
The Power Steering pump and the battery were recently replaced in my 2019 MDX. Since then I've noticed that the car makes a grinding/whining sound when I'm accelerating and even when the car is stopped at a light. It's coming from the front of the car. What could it be?
Old Mar 21, 2015 | 02:07 PM
dice1111's Avatar
8th Gear
2019 MDX? From the future!? Post pics/specs!!! Also tell me loto numbers!
Old Mar 25, 2015 | 03:03 PM
mossman77's Avatar
Sounds like maybe they didn't bleed the system properly. It needs to be vacuum bled, or it will continue to make noise and could damage steering components if left as-is.
Old Mar 26, 2015 | 08:11 PM
Lloyd10977's Avatar
7th Gear
I agree with @mossman77. Air in the pump will usually make a terrible racket. First check to see if the reservoir is filled properly then look for foam, and indication that air is being agitated in the pump. When properly filled, turn the steering wheel back and forth, lock tolock repeatedly until the noise diminishes. DO NOT HOLD THE STEERING WHEEL HARD AGAINST THE LOCK!!!
Old Mar 27, 2015 | 08:45 AM
mossman77's Avatar
Unfortunately, that typically doesn't work on this vehicle (been there, tried that several times). The only thing that resolved it was vacuum bleeding.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Mike734
Dec 10, 2021 01:25 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
copmagnet82
Jun 29, 2016 08:09 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
