Minor jerk when releasing gas?
Hello all, I posted this on another forum with little luck so far. Does anyone have a slight jerk when they let off the gas around 20mph? It's very minor. I've driven it past 20mph and the upper speed range doesn't have this issue, even higher rpm's so I'm starting to think it's not a motor mount issue?
It's like a manual car, when your in first/second gear it's really sensitive and bucks because it's in a low gear perhaps? Thanks!
Ok, had the dealership check it out, they couldn't find the problem, they said everything was great and the only thing they did to it was a software update to the transmission. Ironic thing after I got it and started driving the rpm's were bouncing like there was a vacuum leak. But it drives fine now, disconnected the batter overnight to see how it will turn out in the morning.
