MDX ATF filter replacement question
Old Oct 9, 2010 | 11:05 PM
eztiger12's Avatar
8th Gear
Hi I'm a proud owner of a 2003 MDX.
I have been writing threads on this forum for the last couple of days.......great site, I learned quite a bit.
I planning to change the two
  • 3rd Gear Pressure Switch / Sensor 28610-RAY-003 #13
  • 4th Gear Pressure Switch / Sensor 28600-RAY-003 #12
and
Temp Sensor 28650-RDK-003
since I got the codes read at the dealer and the result being the ATF Temp Sensor. (Yes, I am also planning to change the ATF).
But, My question is.................
Does a 2003 MDX have a ATF filter like in part number:
25450-P7W-003.
All input is appreciated......thanks in advance.
Old Oct 11, 2010 | 09:53 PM
eztiger12's Avatar
8th Gear
Any help would be appreciated.
Old Oct 14, 2010 | 02:25 PM
Majofo's Avatar
Non-serviceable on the 2003 MDX. You have to drop the trans to replace the filter.
Old Oct 26, 2010 | 08:53 PM
survey_sez's Avatar
I Think It's Possible - Tho I haven't Tried
I believe it can be accessed beneath the battery and air intake. See these links:
http://www.piloteers.org/forums/show...threadid=24335
http://www.odyclub.com/forums/showth...=&pagenumber=1
Old Oct 26, 2010 | 10:35 PM
Majofo's Avatar
Like I said before. The ATF filter for the 2003-06 MDX is not serviceable. There is a serviceable ATF filter for the first gen trans on the 01-02 X's. The 03-06 filter is located internally adjacent from the valve body.
01-02 Trans w/ accessible filter
03-06 Trans w/ non accessible filter (notice no banjo fitting leading to filter canister as above)
Old Oct 27, 2010 | 01:49 PM
survey_sez's Avatar
thanks for the clarification!
Old Oct 28, 2010 | 11:01 AM
Mjakaz09TL's Avatar
hey Majofo... CLEAN up your inbox... tryin to pm u! Got some questions for ya on this for our 02 mdx and on timing belt.
Old Oct 28, 2010 | 05:41 PM
mrgobush's Avatar
How often should you change your ATF. I have an 06 MDX and it has not been changed.
Old Oct 28, 2010 | 07:28 PM
survey_sez's Avatar
i changed my transmission fluid when i purchased the car (pre-owned with 50k miles on it). it was very dirty (brown). i also have a 2006. buy a case of ATF - drain and fill 4 times to do a complete flush. in my opinion this should be done at least every 50k miles under normal use. maybe sooner if under heavy use or towing. i was looking forward to changing the filteralso until i read this thread...
cobra10363
Jul 23, 2024 04:13 PM
nanos
Nov 12, 2015 08:41 PM
wusty23jd
Sep 24, 2015 11:41 AM
Skirmich
Sep 15, 2015 06:41 PM
Snafunk
1/2G MDX (2001-2013)
Sep 3, 2015 08:01 PM
