How do you remove the tail lights from a 2007 MDX?
I'm trying to replace the rear sidemarker lights in my 2007 MDX. I can get the two bolts out with no troublee, but no mater how hard I pull on the assembly, it won't budge loose from the pillar. I tried to insert a covered screwdriver between the body (paint) and the lens, but was afraid I would crack it or chip the paint. Any advice?
I'm trying to replace the rear sidemarker lights in my 2007 MDX. I can get the two bolts out with no troublee, but no mater how hard I pull on the assembly, it won't budge loose from the pillar. I tried to insert a covered screwdriver between the body (paint) and the lens, but was afraid I would crack it or chip the paint. Any advice?![Why Me](https://acurazine.com/forums/images/smilies/whyme.gif)
Just to be clear, you are referring to ref #3/10 in this tail light diagram correct?
http://www.acurapartswarehouse.com/P...gPicture=False
If so then it looks like there's a tail light grommet (ref #27) that has to be removed in addition to the two tail light bolts that you have removed. Remove this grommet and just pull hard- the tail light should pop right off
cycdaniel
12-17-2019 10:58 AM
handsom-hustla
11-13-2015 05:04 PM
wusty23jd
09-24-2015 11:41 AM
