Conventional MDX Build
Old Dec 10, 2020 | 04:44 PM
kevin2m4's Avatar
Hey All,
picked up an MDX on the weekend,
2005 mdx 275k KMS vsa tpms light on, srs engine and abs codes in system, has a broken front bumper but is in oddly really good shape otherwise, not much rust at all. 2k Canadian $. Seller said rad cracked internally and he rebuilt the trans and put new rad in a year ago. Timing belt done in 2017.
My driveway looks like an Acura dealership
exhaust leak as well.
Looking into what it needs this week.
Old Dec 10, 2020 | 04:49 PM
kevin2m4's Avatar
Some things
Old Dec 10, 2020 | 04:51 PM
kevin2m4's Avatar
Exhaust leak was a hole in top of the muffler
Old Dec 10, 2020 | 04:56 PM
kevin2m4's Avatar
there was also a whack of tire pressure sensor codes but thats boring
Most of the lights cleared when I ran the erase code command individually on each one,
the yellow triangle VSA light would not clear.
The solution was running the neutral relearn with the car running and the wheel straight.
see pic below
Old Dec 10, 2020 | 04:57 PM
kevin2m4's Avatar
Old Dec 10, 2020 | 05:01 PM
kevin2m4's Avatar
Control arm bushing is split and rear rotors rotty
CAD
Old Dec 10, 2020 | 05:42 PM
DaIll1's Avatar
Originally Posted by kevin2m4
Some things
Oh no, it's having a period.
Old Dec 10, 2020 | 05:58 PM
kevin2m4's Avatar
I fix
Old Dec 10, 2020 | 06:00 PM
kevin2m4's Avatar
I was hoping to add the cassette radio to the car but it doesn't have the same pin for radio antenna
Old Dec 10, 2020 | 06:19 PM
kevin2m4's Avatar
All the couplers were different on the radio.
Used the old one
Old Dec 10, 2020 | 09:03 PM
kevin2m4's Avatar
Transmission Drain plug
Wut
Uhhh
Old Dec 10, 2020 | 09:15 PM
kevin2m4's Avatar
On the back of my radio there is a green plug that isn't used. Anyone know what it's for?
Old Dec 11, 2020 | 01:02 PM
kevin2m4's Avatar
Looks like it's for CD changer, but there is an ipod and aux that can plug into it.
I will get one
My spare heat controls had one bulb out so I took the one that was completely dead apart.
Didn't have the bulb it needs in my bag of bulbs but will try.....heated seat switch bulbs I think
Old Dec 22, 2020 | 09:05 PM
kevin2m4's Avatar
Tried a few other bulbs
Pulled bulbs out
Replaced with led. I tried 4 of them both ways. Not sure why didn't work.
Old Dec 22, 2020 | 09:08 PM
kevin2m4's Avatar
Had these ones on hand from ebay from another car
They worked but aren't the right color. Good enough, better than being out.
Old Dec 22, 2020 | 09:09 PM
kevin2m4's Avatar
They kinda match the screens
Old Dec 28, 2020 | 03:43 AM
TLOHTL's Avatar
Good job
Old Dec 28, 2020 | 01:21 PM
kevin2m4's Avatar
Seeds in seats
Hello little friend
Old Dec 28, 2020 | 02:36 PM
kevin2m4's Avatar
Rear heat didn't work, I soldered a wire skipping the thermal cut off in the blower resistor but forgot to take a Pic. But the intake screen was full of dust and lint. Also under center console was full of seeds. 0$ repair I was very happy.
Old Dec 28, 2020 | 09:13 PM
kevin2m4's Avatar
Bought some wood.
Be here in a few weeks
Old Jan 5, 2021 | 02:27 AM
kevin2m4's Avatar
Anyone know why this happens?
I get to a quarter tank and it says 0km left, then I get below a quarter and it reads - - -
Old Jan 5, 2021 | 03:57 PM
kevin2m4's Avatar
One drawback is the 05 mdx doesn't have a cassette player for an aux adapter or and aux input. Luckily it did have the option of an auxiliary CD changer accessory.
I ordered a USB and aux kit. Should be here from China in a few weeks.
Hoping to install them both into the ashtray but not an ashtray.
Old Jan 5, 2021 | 04:05 PM
kevin2m4's Avatar
D light started flashing. All the other lights remain out that were on when I bought it.
Old Jan 7, 2021 | 04:16 PM
kevin2m4's Avatar
Shifter started getting stiff going into park
Spray lubricated this area and it is fine now
Old Jan 13, 2021 | 11:12 AM
kevin2m4's Avatar
Got the wood gauge bezel surround
While it was out I replaced the cluster dim light and the sel reset light. The dimmer light is yellow because I stole it from the 'vtm lock on' switch of the old, not wood bezel and I didn't peel off the rubber yellow film on the bulb.
Old Jan 15, 2021 | 12:17 AM
kevin2m4's Avatar
Shift knob came in
Old Jan 15, 2021 | 10:35 AM
kevin2m4's Avatar
Aux unit came
Tried routing it through the Nota ashtray but ended up doing it under. No drilling
Old Feb 22, 2021 | 12:24 PM
kevin2m4's Avatar
Fuel economy has been really bad. This is litres per 100km or 12 mpg. I was going to do the spark plugs myself but have to time and it's been near - 20c outside so I had the shop do them. Tech said 2 were seized and 2 were loose. The 2 that were loose had carbon on the threads that needed to be tapped and replacing the plugs fixed the ticking exhaust leak from the front. He believed they were original plugs
Economy improved, engine is quieter, more power.
Old Feb 23, 2021 | 09:07 AM
vpasla1's Avatar
Great job so far.
Old Feb 23, 2021 | 09:13 AM
kevin2m4's Avatar
Originally Posted by vpasla1
Great job so far.
Thanks!
Old Feb 28, 2021 | 11:09 PM
kevin2m4's Avatar
My tailgate doesn't open very high
I hit my head every time
I got similar struts, longer ones from an older sienna
Will try them soon
Old Mar 10, 2021 | 05:30 PM
kevin2m4's Avatar
Old Mar 10, 2021 | 05:36 PM
kevin2m4's Avatar
Now I don't hit my head
The top mount angle isn't the same but I think it will work
Old Mar 10, 2021 | 08:51 PM
dzionny_dzionassi's Avatar
So you bough fake Chinese pressure switches...
Old Mar 10, 2021 | 09:15 PM
kevin2m4's Avatar
If that's a question you forgot your question mark
And yes I did they were 1/5th the price and the d5 doesn't blink anymore
4th Acura
3G MDX Photograph Gallery
Jul 30, 2021 04:45 PM
fmallabykay
Dec 11, 2020 04:01 PM
DANMAN421
3G MDX (2014-2020)
Aug 24, 2019 03:05 PM
wedesmet
Feb 26, 2011 01:18 PM
Rexorg
1/2G MDX (2001-2013)
Jan 1, 2011 10:59 AM
