A/C temp on drivers side warm, passenger side cold
Old Jul 31, 2017 | 09:18 PM
MarkHJ's Avatar
2008 MDX tech
Old Aug 1, 2017 | 02:57 AM
Crashmaster's Avatar
Blend door motor likely bad
Old Aug 1, 2017 | 03:07 PM
AlanW's Avatar
2006 NBP TL MT6/ 02TL-S
I've got an 08 MDX Tech. It was doing that when we first got it-blowing cool on the passenger side & warm (but not hot) on the driver's side. It was simply low on Freon. Now if yours is actually blowing HOT air on driver's side, then blend door.
Old Aug 1, 2017 | 07:13 PM
EE4Life's Avatar
Forum Contributor
Your issue is most likely due to a low refrigerant charge.
See the following article on page 1 of the July 2012 Acura Service News:
Left Dashboard Side Vent Is Warmer Than Right With A/C On
https://acurazine.com/forums/third-g...8/#post8398357
Old Oct 30, 2017 | 09:04 AM
nynruas's Avatar
I have cold air coming out of the driver's side vents and hot air out of the passenger side. Both sides set at 85 (for testing). I'm guessing it's this blend door, you are mentioning. Are they easy to repair/replace? Thanks in Advance.
mgfenginc
Nov 10, 2017 12:22 PM
Gmguy88
1G RDX (2007-2012)
Oct 10, 2017 09:06 AM
psnoak
Aug 22, 2017 07:38 PM
TL-Syndicate23
Aug 14, 2017 12:10 PM
Eve07
4G TL Problems & Fixes
Aug 11, 2017 02:38 AM
