A/C problem
Old Oct 4, 2012 | 10:58 PM
CAB NY's Avatar
Tri State ViP Crew
A/C problem
i have a 04 MDX and does anybody have an idea what can be the problem with the A/C it starts cold and then it will start blowing warm air then later on the cold starts again
thanks
Old Oct 5, 2012 | 12:35 AM
CAB NY's Avatar
Tri State ViP Crew
i was doing some research and found some info. if i have it right about the compressor coil stator could be bad any knowledge of this
thanks
Old Oct 5, 2012 | 12:39 AM
larso1's Avatar
thanks
Check the simple things first. Have the freon charge checked. Could be a slow leak from a tube fitting / compressor seals.
Old Oct 5, 2012 | 01:37 AM
CAB NY's Avatar
Tri State ViP Crew
had it check fully charged a/c is cold then gets warm after about 10-15 minutes then cold again
Old Oct 5, 2012 | 01:50 PM
yungone501's Avatar
J-series addict
Can you confirm wether or not the A/C compressor clutch disengages or not?
Also, do the fans in the engine compartment stay on regardless if its blowing cool air or not?
Two most common things I see here around the shop that affects these MDXs:
1. Evaporator temperature sensor (located behind the glove compartment)
2. A/C pressure switch (located right between the engine comaprtment fuseblock and power steering return line into pump)
Lastly, look around online for the self-test you can do right on the HVAC control panel itself. Its pretty lengthy or else I would post it but a quick Google search should show you what/how to do it.
Old Oct 5, 2012 | 06:43 PM
CAB NY's Avatar
Tri State ViP Crew
i will definitely do the search but if you can post it i would appreciate
thanks
Old Oct 5, 2012 | 07:55 PM
CAB NY's Avatar
Tri State ViP Crew
is there any special way to confirm if the compressor clutch is disengaging
Old Oct 27, 2012 | 02:20 PM
CAB NY's Avatar
Tri State ViP Crew
went to the dealer to check my A/C on my 04 MDX because it would blow hot air after 10 -15 minutes i was told i need to change the clutch and coil and relay and the dealer wanted 1198$ parts and labor are they sold as one or separate items i try to find the parts but came up with just clutch coil part # 38924-RCA-A01 or a/c compressor coil /stator set thanks
__________________
Old Oct 29, 2012 | 07:17 PM
PaulAWD's Avatar
Now that you know the problem have a independent mechanic quote you. It might not be cheap but I'm sure it will be less then the dealer.
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
