A/C problem
Tri State ViP Crew
A/C problem
i have a 04 MDX and does anybody have an idea what can be the problem with the A/C it starts cold and then it will start blowing warm air then later on the cold starts again
thanks
thanks
Check the simple things first. Have the freon charge checked. Could be a slow leak from a tube fitting / compressor seals.
J-series addict
Can you confirm wether or not the A/C compressor clutch disengages or not?
Also, do the fans in the engine compartment stay on regardless if its blowing cool air or not?
Two most common things I see here around the shop that affects these MDXs:
1. Evaporator temperature sensor (located behind the glove compartment)
2. A/C pressure switch (located right between the engine comaprtment fuseblock and power steering return line into pump)
Lastly, look around online for the self-test you can do right on the HVAC control panel itself. Its pretty lengthy or else I would post it but a quick Google search should show you what/how to do it.
Tri State ViP Crew
went to the dealer to check my A/C on my 04 MDX because it would blow hot air after 10 -15 minutes i was told i need to change the clutch and coil and relay and the dealer wanted 1198$ parts and labor are they sold as one or separate items i try to find the parts but came up with just clutch coil part # 38924-RCA-A01 or a/c compressor coil /stator set thanks
__________________
__________________
SidhuSaaB
05-30-2020 12:40 AM
