Any trick to remove camshaft oil seal?
Old 02-17-2018, 02:43 PM
VictorTL's Avatar
I am doing timing belt, water pump, fix oil pump leak, removing oil pan. Lots of work!! What is the trick to remove and install camshaft oil seal
Old 02-19-2018, 03:05 PM
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
Trick? there is no trick just carefully pry it off with a flat screwdriver. Be extra careful on not to scratch the camshaft shaft.
Old 02-19-2018, 06:51 PM
VictorTL's Avatar
ok thank
Old 02-19-2018, 07:45 PM
Skirmich's Avatar
Might I ask.. Why are you changing these? are they leaking?
Because if they arent, you might wanna reconsider.... Those seals are not usual replaceable items, more like. Replace when they leak and that is very rare.
With those seals the phrase "If aint broke...." fits like a glove, specially the Rear and Front Main Seals.
Old 02-20-2018, 05:10 PM
VictorTL's Avatar
i don’t know if they are leaking or not until I remove the camshaft pulley but I want to be prepared just in case they are leaking. I want to get as much info as possible before the tear down. It is not practical to ask for info while everything is removed. I have only one car and I can’t have it sitting around for days waiting for answer. You know what I mean.
Old 02-20-2018, 08:28 PM
Skirmich's Avatar
You are changing the camshaft from your motor right due to scoring?
Old 02-21-2018, 06:56 AM
VictorTL's Avatar
not at this time. I will tackle that project in the summer.
Old 02-21-2018, 07:02 AM
VictorTL's Avatar
Do they make these door seals for the mdx?
Old 02-23-2018, 03:37 PM
Skirmich's Avatar
Which ones?
james21_h
07-11-2018 12:15 PM
winkyyy
09-11-2015 04:40 PM
badjuju98
05-28-2014 02:18 AM
victus1
07-04-2012 07:42 AM
victus1
06-04-2012 05:29 PM
Quick Reply: Any trick to remove camshaft oil seal?
