2006 Acura MDX makes grinding noise when accelerating
Old 08-05-2020, 07:12 PM
4th Gear
dukenukemx's Avatar
My sisters MDX makes a grinding noise when it accelerates from a stop. Doesn't happen when moving at a decent speed or a highway. I can't figure out what the cause of the problem is. I checked the catalytic converters and none of them rattle. The CV axle boots don't look ripped or leaking. The only thing I can thing of is maybe the front struts are bad because they make a slight clunk when hitting bumps. I made a video so maybe someone can help me.
https://youtu.be/tZrew_v60aw
Old 08-05-2020, 10:56 PM
Received 16,260 Likes on 11,971 Posts
very odd, never heard that sound before
perhaps a driveline issue!? or something to do with shawd?
Old 08-06-2020, 10:07 AM
4th Gear
dukenukemx's Avatar
I thought it maybe a bad CV axle but I tried pulling on them with my hand and nothing seems to move. I've already changed the front right last year so that can't be it. I looked at the axle yoke for the drive shaft to see if there's any play and nothing. Hopefully nothing with the transmission. I did change the transfer case oil yesterday with gear oil as that hasn't be done. What I'm going to do is order new front struts and change them since I know they're not in great shape. You hear this clunking noise when hitting a bump like the strut mount has gone bad. Maybe that'll fix the problem?
Old 08-06-2020, 10:08 AM
yeah, cv axle wont sound like that. cv axle will sound more like a clicking sound
but your noise DID happen on a turn, so perhaps it is a CV axle?
Old 08-07-2020, 12:58 PM
4th Gear
dukenukemx's Avatar
It happens going straight or turning, but it's easier to make when turning. It doesn't happen when I'm moving at a good speed. It won't happen on the highway and it doesn't happen above 20 MPH. It's as if the engine needs to strain against the car hard in order to make the noise.
Old 08-07-2020, 01:48 PM
just full disclosure; I dont have an MDX.
just going on my automotive knowledge.
I think we can rule out the CV, because you didnt see any abnormalities during your visual inspection and it def. doesnt sound like a CV clicking.
Old 08-07-2020, 03:36 PM
csmeance's Avatar
Received 1,991 Likes on 1,414 Posts
06 mdx doesn't have SH-AWD just the VTM-4 system. I'd venture into believing there is an issue with the differential inside the transmission or the transfer case.
justnspace (08-07-2020)
Old 08-07-2020, 03:53 PM
^ as that would make a grinding noise, as perhaps a tooth broke
Old 08-12-2020, 09:27 AM
4th Gear
dukenukemx's Avatar
Is that the transfer case looking thing in the back of the trans? I think someone changed it at some point because it looks newish. My sister bought it used years ago so who knows what the previous owner did to it. Are these known to have issues on MDX's?
Old 08-12-2020, 05:30 PM
csmeance's Avatar
I'm not sure if it's a common issue, but a lack of fluid changes can destroy any type of differential/transfer case. I'm not that familiar with the 1G MDX but I'm guessing yes, after the trans should be the transfer case.
Old 08-12-2020, 05:31 PM
i'm thinking the same. not a common issue but can happen to any car
Old 08-14-2020, 08:12 PM
Aftermarket axles will cause a grinding noise at the same points you described
https://acurazine.com/forums/3g-tl-p...mptoms-989325/
helping out this guy and I immediately pinpointed it to the aftermarket axles he used. then I immediately thought of you.
Perhaps your sisters MDX has aftermarket axles.
Old 08-05-2023, 03:21 PM
kvault's Avatar
Figure it out?
did you ever figure out what was going on? My daughters MDX is having the same exact issue.
WJO1994
06-06-2019 05:36 AM
NBPacuraTL
1/2G MDX (2001-2013)
04-02-2010 08:52 AM
junyim
12-13-2008 08:00 PM
capriguy
1G TSX Problems & Fixes
11-09-2006 08:53 PM
Quick Reply: 2006 Acura MDX makes grinding noise when accelerating
