2004 Acura MDX Brake Pads and Rotors
Old Feb 22, 2011 | 04:13 PM
FiftyFive's Avatar
Moderator Alumnus
I have to replace my brake pads and rotors on all 4 sides in my 2004 Acura MDX. I was quoted by my local mechanic for $800.
Does this seems reasonable?
Old Feb 22, 2011 | 04:27 PM
007Acura's Avatar
seems like a good fair price, I would still call a few other places including Acura just to compare.
Old Feb 22, 2011 | 04:42 PM
TL black's Avatar
pads front and rear 85 bucks at pepboys, and I believe you can find rotors for under 50 a piece. I did the pads on my 06 my self and they are super easy. doing the rotors is not much more work. do one wheel at a time. your rotors are probably fine any way if your pads did not cut into them they should be fine.
Old Feb 23, 2011 | 02:50 AM
Chr8808's Avatar
IMO, for $800, he's better be using OEM Acura parts. If he's using generic pads/rotors, thats too much.
my
As previous poster mentioned, pads are easy to change, and the rotors are even easier - that is, if youre interested in DIY.
Old Feb 23, 2011 | 12:13 PM
FiftyFive's Avatar
Moderator Alumnus
Debating on whether or not to do it myself. Anyone have a DIY? Not sure if I have all the tools, etc.
Old Feb 23, 2011 | 03:45 PM
Chr8808's Avatar
Socket set - 8 and 12MM sockets i think,
C-clamp or a C-clamp plier (for pushing back piston)
impact driver (to remove disc)
I'll see if i can find a DIY but its very very easy
Old Feb 23, 2011 | 04:38 PM
FiftyFive's Avatar
Moderator Alumnus
^^ Thanks man! Let me know if you find anything else!
Anyone know of a reputable site to get pads/rotors?
I want to make sure the rotors are decent quality, don't want vibrations in ~10,000 miles lol
Old Feb 24, 2011 | 09:31 AM
Chr8808's Avatar
You can follow this DIY: Its basically the same thing
https://acurazine.com/forums/2g-tl-performance-parts-modifications-116/diy-rotors-pads-%2A%2Ahow-w-pictures%2A%2A-620983/
I used stock acura pads (got them at A&H motors in PA-they mail order acura & honda parts).
Old Feb 24, 2011 | 03:42 PM
FiftyFive's Avatar
Moderator Alumnus
https://acurazine.com/forums/showthread.php?t=620983
Thanks man, you may have just saved me a lot of money. I will probably do it myself.
Old Feb 25, 2011 | 01:01 AM
OutkastSL's Avatar
its easy to do, if you got the right tools. I'm in a wheelchair and still change my own brake pads and rotors.
Old Feb 25, 2011 | 08:49 AM
FiftyFive's Avatar
Moderator Alumnus
That's awesome! So there is 3 bolts total on the caliper that have to be removed?
Old Feb 26, 2011 | 12:35 AM
OutkastSL's Avatar
from what I remember, two bolts per caliper and one set screw for the disk. It took me 15 minutes per side with air tools and my brother in law doing the heavy lifting for the wheels.
Old Feb 28, 2011 | 12:38 PM
vas25tl's Avatar
The Box
I ordered front and rear pads for $110 from a guy at a Honda dealer in California.
You can find good prices on OEM parts online.
Old Feb 28, 2011 | 04:56 PM
FiftyFive's Avatar
Moderator Alumnus
I'm actually a little wary about buying Acura OEM rotors, they're not the greatest.
Old Mar 13, 2011 | 10:11 AM
FiftyFive's Avatar
Moderator Alumnus
Gonna be taking care of the brakes in a few, any last tips/tricks? lol
Does anyone know the proper bolt torque specs for the caliper, etc?
Old Mar 13, 2011 | 02:26 PM
FiftyFive's Avatar
Moderator Alumnus
Ran into a little hickup, the new brake pads I got don't have the little hole for the wishbone shaped spring to go in to? What should I do? Not use the spring? Drill the hole for it?
Old Mar 13, 2011 | 07:43 PM
vybzkartel's Avatar
The springs are called 'pad spreaders'.
When I changed my brakes in October, the new pads I got didn't have the holes for them, but I knew that before I bought them(they're cheaper). I figured as long as I use the 'disc brake quiet' paste, I didn't need them.
This is the 1st vehicle I've owned with them. Also the 1st one with twin piston calipers. Don't know what their purpose is....maybe to help keep the pads away from the disc, or even the resistance because of the 2 pistons?
I don't notice any difference with or without them.
Old Mar 13, 2011 | 09:11 PM
FiftyFive's Avatar
Moderator Alumnus
Yea, i just went along without them. The whole process took about 6.5 hours. I had a hard time getting the back rotors off.
Other than that everything went kinda smoothly. I hear a little noise now but I think that is supposed to go away after the break-in. Hopefully it does!
Old Mar 16, 2011 | 09:03 PM
OutkastSL's Avatar
sorry i didn't get your pm until today. like vybzkartel said they are brake spreaders and it's purpose is to reduce brake noise.
Old Mar 20, 2011 | 05:09 PM
FiftyFive's Avatar
Moderator Alumnus
So everything seems to be ok as far as braking, i do hear a clunk when going forward after a moderate brake. What could this be?
Old Mar 21, 2011 | 08:43 PM
FiftyFive's Avatar
Moderator Alumnus
Looks like the fronts caliper bolts had to be tightened to 101lbs/ft, just tightened them up now.
Any idea what the rear caliper brackets are supposed to be torqued to? I can't find the info anywhere.
Old Mar 22, 2011 | 08:52 AM
vybzkartel's Avatar
My service manual shows 41 lb/ft, for the rear caliper bracket.
Old Mar 22, 2011 | 12:20 PM
FiftyFive's Avatar
Moderator Alumnus
Thanks!
mada51589
Jan 9, 2025 04:40 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
nishant11
Sep 2, 2015 10:34 AM
