2002 mdx heater only warm not hot air
Old 01-27-2017, 05:38 PM
3rd Gear
pearsrs's Avatar
My 2000 MDX had no hot air so i start reading and this is what i have checked so far:
1. I think thermostat is ok seeing the engine heats up to the same mark on the temperature gauge and normal and the fans turn on and off as needed.
2. The water control valve along the fire wall is ok seeing it moves when i turn the knob from hot to cold.
3. The blend door linkage on the also moves when the thermostat know is moved.
4. I flushed the system with the prestone chemical cleaner.
5. Both the inlet and outgoing hoses are warm/hot after the engine warms up.
I have not remove the actuator for the blend door (pain in the A**) based on the location so if there are other suggestions on easier possible solutions I could try i'm open to trying it.
Bob
Old 01-28-2017, 07:26 AM
AZ Community Team
Legend2TL's Avatar
Received 4,039 Likes on 2,513 Posts
You've done everything I would do. Here's a couple other suggestions
1) check if there's any air flow blockage of the hear exchanger. Rare but it's possible some debris blocking the airflow.
2) get a USB endoscope probe camera (they're pretty cheap on eBay ~$12) and use that to see the motion of the mix door. It's far better than trying to take it apart.
rbailey86
01-25-2017 10:15 AM
TSX1012m6
12-25-2016 10:19 AM
99three2l
03-24-2014 12:58 PM
AMGala
09-27-2010 12:58 PM
Quick Reply: 2002 mdx heater only warm not hot air
