2008 Acura TL
Old Jan 25, 2017 | 07:24 AM
rbailey86's Avatar
2008 Acura TL
Hello everyone...
I have no heat at all at idle (blows cool) then when driving or the RPMs go up the heat is luke warm at best....its been getting progressively worse
I am in the auto business so we have checked all of the obvious
My TL has 190,000 miles FYI (highway)
-New thermostat.
-No coolant leaks
-Coolant is completely full
-Bled system of air
-Heater control valve does move when changing temperatures
I am leaning towards heater control valve issue though as I see some people have had this problem?
Advice?
Old Jan 25, 2017 | 07:47 AM
did you make sure the thermostat was installed in the proper orientation? Some people have had issues with that. That, or the oring was improperly installed
Old Jan 25, 2017 | 08:17 AM
rbailey86's Avatar
yes it is installed properly
when the problem started I replaced the thermostat
same problem before and after
Old Jan 25, 2017 | 10:15 AM
check out this DIY theN: https://acurazine.com/forums/third-g...ve-diy-747304/
