07 MDX Replace Battery, now power window doesn't open
Old Mar 10, 2013 | 08:33 PM
Rocco_10's Avatar
Smile 07 MDX Replace Battery, now power window doesn't open
I had a dead battery on my 07MDX this past week and I had CAA replace the battery.
Everything works fine on the car, but now my passenger side window switch which is located on the driver door does not open the window. But if I use the switch on the passenger side door, the window works.
I was speaking to a friend and he is telling me that sometimes when you replace the battery, the computer controlling the windows needs to be reset.
Is this true?
If so, can anyone help me on how to reset the computer?
Old Mar 26, 2013 | 02:19 AM
Wildcrd76's Avatar
You just have to roll the window down and hold the switch down for 2 sec. Then roll the window up and hold for 2 sec. You should hear a click. After that the window should work again with the driver side controls. This reset is down with the passenger side control. Hope this helps
Old Mar 26, 2013 | 10:19 AM
Rocco_10's Avatar
Thank you very much.
I tried your solution and it worked.
Thanks again!
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
mazen222
Oct 27, 2015 12:01 AM
3.5RLv-tec?
1/2G MDX (2001-2013)
Sep 7, 2015 11:00 PM
Phambam12
Sep 6, 2015 06:57 PM
