iJDMtoy Led DRL Harness Install w/Pics
Old 07-09-2012, 05:27 PM
  #161
Registered Member
The Machine's Avatar
Originally Posted by con5tant
edit: This worked for only about 20 mins..when i turned the car off they did not come back on (still no DRL on dash tho). Switched drivers side and they worked again.
LOL! And I've had the kit installed for 3 months today and the double sided tape I used on page 1 is holding up just fine.
Old 09-05-2012, 10:31 PM
  #162
ATLSahota's Avatar
Just finished installing these. They look great, 5/10 difficulty doing it. Any ideas n where good places to mount resistors?
Old 09-06-2012, 09:53 AM
  #163
Registered Member
I would just use the locations I have pictured on page 1. There isn't a ton of slack in the wiring to try and find other places to mount them. The areas I put them in are away from other wiring (because the resistors get red hot!) and it was the flatest surface I could find so that I could put enough double faced tape to hold them in place. Just make sure you clean that area from any dirt so they can stick to the best of their ability.
Also on a side note for anyone that may ask. My double face tape from when I orginally installed these, is holding up just fine.
Old 09-06-2012, 10:59 AM
  #164
Desert Life Sucks!!
sauceja's Avatar
My tape is also, even though one has been wiggly since day one. My whole drill - tap - screw method didn't work so relying on double sided 3m tape to do the job.
I have had zero problems with this mod since install.
Old 09-06-2012, 01:29 PM
  #165
Registered Member
Hmm, not sure why it would wiggle. Where I mounted mine both sides were pretty flat IIRC. I used a square at each end of the resistor and not just one piece in the middle and those things are rock solid in place. Even if I try to wiggle mine they don't come loose.
In any event, at least it still is holding fine and you are problem free!
Old 09-06-2012, 01:39 PM
  #166
Desert Life Sucks!!
sauceja's Avatar
I had intended to use bolts so where I mounted it the whole piece is not flat. There was some overlap. So it wiggles a little.
I have been monitoring it and holding fine.
Old 09-08-2012, 03:53 PM
  #167
thenamesian's Avatar
anyone have any pics of iJDM DRLs with Lamin-X gunsmoke on the headlights? i am concerned that the DRLs will be barely visible with the Lamin-X gunsmoke (12%) on.
thanks!
Old 09-08-2012, 04:59 PM
  #168
Registered Member
thanks!
Hmm, I don't think many people are going to have a pic of this. Not a ton of people on here run this kit and probably just as few have lamin-x tint on their headlights. Any reason you have the headlights tinted so dark? How is your headlight output driving at night?
These LED drl's have decent output, but with such dark tint I don't think they will look super bright. You can always try the kit out and if you don't like the output maybe use a lighter shade of tint (if you must have it on there) or take the tint off completely.
sauceja (09-08-2012)
Old 09-08-2012, 10:57 PM
  #169
Desert Life Sucks!!
sauceja's Avatar
I don't even care about the output of these. I just hate the way halogen DRL's look. I laugh everytime I see a newer civic with dull crappy halogen DRL's. I even get glances from BMW and Mercedes drivers when they see my car at the light during the day.
Old 09-09-2012, 05:26 PM
  #170
Registered Member
Damn straight! I wasn't so much concerned with having super output either. Since I actually do like the looks of the DRL's on our cars, I more or less wanted a nice clean look to them and not the dull yellow of the halogen bulbs.
Old 09-13-2012, 06:07 PM
  #171
ill try to post some pics when i install them - i don't care about light output either, they'll be on in the day so no big deal at all.
Old 09-15-2012, 07:35 PM
  #172
great08's Avatar
Note to ijdmtoy
My ...
ijdmtoy should link to this thread and youtube video on their website. The provided wiring diagram is laughably simple, and I think anybody doing this kind of install would benefit much more by coming here!
The Machine (09-16-2012)
Old 09-16-2012, 11:18 AM
  #173
Desert Life Sucks!!
sauceja's Avatar
I have sent them a link to this thread back when they sent me wrong connectors.
Old 09-16-2012, 04:54 PM
  #174
Registered Member
Originally Posted by great08
My ...
Thanks guys, I appreciate that!
The following 2 users liked this post by The Machine:
Mondo375 (09-16-2012), sauceja (09-16-2012)
Old 09-20-2012, 05:21 PM
  #175
v|nsan|ty's Avatar
So one of my LEDs has gone bad and it flickers all the time. I figured I'll just grab another pair off ebay so I went with these: http://www.ebay.com/itm/2X-Car-120-L...712675&vxp=mtr
When they arrived I tried to install them but as it turns out, the diameter to the head is too big to fit into the hole for the DRL. I didn't think to measure the bulb as I assumed 9005 should be universal. The measurement on these ones is 2cm, 20mm.
Anyone running bulbs like this and can confirm they'll fit the socket? The listing mentions they're 18mm
http://www.ebay.com/itm/HB3-9005-68-...e42352&vxp=mtr
These look like the ones that used to be included with the Acura kit but looks like they took it down now, most likely since it never worked. Their measurement appears to be 18.6mm in diameter.
http://www.v-leds.com/6K-WHITE-28-LE...-p7652845.html
I know it seems like I may be over thinking this but I don't want to order another pair of bulbs and have them collecting dust in my closet since they don't fit.
Old 09-21-2012, 06:15 AM
  #176
Registered Member
You should be fine with any 9005 68 SMD bulbs you buy as they are the same size the kit comes with.
The 120 SMD bubs are probably just a bit too big for the holes because there are more LED lights on the tree making it longer in length and wider in diameter.
Old 09-21-2012, 04:03 PM
  #177
guys, i'm installing my lamin-x gunsmoke headlight covers this weekend. anyone have experience with logevity in the CREE DRLs from JLC? http://www.jlclightings.com/9005-CRE.../001125-13.htm
i will probably install those as i've read they're brighter (easier to see behind the Lamin-X 12%) but i'm concerned about the heat output from the CREEs.
thanks - i will post pics when possible.
Old 09-21-2012, 05:27 PM
  #178
Registered Member
I never knew JLC made a DRL kit. Either one you go with the LED's are probably going to be about the same brightness. I'm not quite sure if you'll be able to use this write up as a guide though because I have never seen their wiring.
Also LED's don't really put out any heat. You can hold the bulbs in your hand when they are lit so you're not going to hurt anything on the car.
Old 09-21-2012, 05:34 PM
  #179
KJ TL-S's Avatar
As a quick update, thought I would show some pics of how my resistors are holding up. One I mounted with double-sided industrial, velcro style tape. Other is just slipped into the area above the fender. Neither has ever moved, the tape held strong throughout the entire hot summer we had here, so I'm pretty sure its never going anywhere.
The Machine (09-21-2012)
Old 09-21-2012, 05:42 PM
  #180
Registered Member
^^ Nice. I always used that type of velcro to hold my ez pass to the windshield in my other cars, good stuff.
Old 09-21-2012, 06:55 PM
  #181
ParaSurfer1979's Avatar
I have a question for you guys. Do they make H7 3000k LED bulbs for the fog lights? If they do, would the be brighter than the stock 35watt halogen bulbs in there stock? If i went this route, I'd want these bulbs to be effective cutting through fog/rain on the road.
Old 09-21-2012, 06:58 PM
  #182
sockr1's Avatar
Received 1,158 Likes on 909 Posts
i have been running the JLC DRL kit for about a year now no issues at all. i don't have the CREE version though. let me know if you need help with the set up, i talked a lot with JLC and another member when we were getting it all set up.
Old 09-21-2012, 07:12 PM
  #183
KJ TL-S's Avatar
Pretty sure you don't want LED fogs then. They are bright to look at, but don't actually put out much useable light to illuminate the road. There is a more technical way to say that I'm sure, but hopefully you understand my point.
Old 09-21-2012, 07:13 PM
  #184
KJ TL-S's Avatar
Haha, just realized me and sockr1 have almost the same avi.
Old 09-21-2012, 07:37 PM
  #185
sockr1's Avatar
haha except i have no aspec kit ...couldnt make my mind up on that one!
Old 09-21-2012, 07:47 PM
  #186
M.I.N.O.'s Avatar
Have any Canadian TLers here used the ijdmtoy or JLC harness without any issues? I'm running LED DRLs with a makeshift harness that I wired up, but the DRL light shows up on my dash. I know the DRL/lighting setup is not the same for U.S. spec TLs, so I just want to make sure I'm not purchasing a harness for nothing.
Old 09-21-2012, 08:52 PM
  #187
KJ TL-S's Avatar
Make the plunge! You won't regret it.
Old 09-22-2012, 02:40 PM
  #188
Registered Member
Yes, KJ is right, LED's are pretty bright to look at directly, but they really don't have great output for lighting up the road as you want. You might want to look into installing HID fog lights then. I have the kit from theretrofitsource.com and love them. The fog lights are H8 though not H7.
I'm not too sure about this one. You may want to reach out to ijdmtoy and ask them about the kit and if it would work on the Canadian spec TL's.
Old 09-23-2012, 10:33 AM
  #189
UA7 6MT
TmaX's Avatar
The harness is not to avoid the DRL Light but to provide full power to the DRL.
I ran the iJDMToy DRL on my 06 CDN TL with a DRL Light but it didnt bother me.
Was able to get the DRL to go away by adding a second set of resistors but the light output was then greatly decreased.
DRL Light doesn't really bother me but to each their own.
I'm about to install it into my 07 Type-S along with a slew of other LED's as well.
M.I.N.O. (10-02-2012)
Old 09-28-2012, 10:14 PM
  #190
snake212's Avatar
Originally Posted by Silvertl88
i've had this kit from ijdmtoy installed for a while now with no problems but all of a sudden the passenger bulb was dimming while the car is running. it will start out normal and then dim. this will continue to happen going back and forth from normal and dim.
Please let me know if anyone has any advice on how to solve this issue.
Video below:
http://www.youtube.com/watch?v=_3Vbl3NDi6E
I been having the same problem. I bought the resistors and bulbs from vleds, and the relay harness I had myself. I started noticing when behind a vehicle i can see the reflection of my DRL's. 1 of them will be dim and then get full power again. sometimes it would stay dim for a while unless i turn my headlights on for a while then off so the DRL's come back on. I also bought new bulbs from a buddy of mine which are different from the vleds, and i still have the same issue so im guessing its the resistor itself. If you found a fix or anybody else did please share because they look very nice hate to stick with the halogen bulbs for long.
Old 12-29-2012, 08:35 PM
  #191
great08's Avatar
Nice DIY =)
I wonder if they sell something similar for us Canadians with DRLs.
I ordered the kit online and installed it in my '08 TL, no problems. I'm in Vancouver.
Old 01-13-2013, 01:25 AM
  #192
7th Gear
Fogz's Avatar
DIY DRL iJDMTOY Kit
Installed my iJDMtoy kit tonight after reviewing your pics, thanks a lot. My kit came with additional connectors (thought hopefully to correct the red to red/red to black connector error, wasn't the case.) and installed in a relatively short period of time. Though, 1 of the LED bulbs didn't work! Decided to uninstalled and roll with the original fogs instead of just 1 working LED. Sending the broken one back, hopefully they send a replacement one quickly.
Old 01-13-2013, 07:54 PM
  #193
Registered Member
^^ You're sure it's a bad bulb right? I hope you tested the "working" bulb on the opposite side to make sure it's actually the bulb that is bad and not something else that's faulty.
Old 01-24-2013, 03:23 PM
  #194
Desert Life Sucks!!
sauceja's Avatar
Yup, possible ground on that side or something else. Extra wire?
Did you take pics of any of the install or anything?
Old 01-24-2013, 07:16 PM
  #195
J_AZ's Avatar
I dont mean to thread jack, but I too just received a ijdmtoy kit. It came with an extra set of connectors as you mentioned. I Just wanted it see if I need this or if I can install like you guys did.
Attached Thumbnails iJDMtoy Led DRL Harness Install w/Pics-photo.jpg
Old 01-25-2013, 08:01 AM
  #196
Registered Member
J_AZ, those connectors in the bag will not be used. Mine also came with 1 extra connector, but it didn't look like that. Since your kit is newer they may have changed what the connectors look like and gave out 2 of them instead of one. You should be good to go.
Old 01-25-2013, 08:16 AM
  #197
KJ TL-S's Avatar
Hey, anyone besides The Machine switch to a 5000k bulb? I'm looking to do so, but his seller doesn't have it listed anymore and I don't want to order a different one and have it be the same 6000k color as these.
Old 01-25-2013, 08:54 AM
  #198
Registered Member
KJ check these out: http://www.ebay.com/itm/2-HB3-9005-6...09e086&vxp=mtr
They look very white and are cheap! I would stay with the 68SMD though, no matter what brand you go with. I think, I remember someone saying the 120SMD bulbs were too big to fit inside the DRL housing.
Old 01-25-2013, 09:14 AM
  #199
KJ TL-S's Avatar
Cheap enough to be worth try, so I went for it! Thanks Chip, you're right, they do like pretty white.
Old 01-25-2013, 01:21 PM
  #200
Desert Life Sucks!!
sauceja's Avatar
J those connectors look like they go from the black connector on the resistor to the bulbs. It may be the new style ones. As they were shipping with ones that didn't work well.
And KJ I also went with the 5k ebay led bulbs. They aren't much different but match better to what I have.
Quick Reply: iJDMtoy Led DRL Harness Install w/Pics
