VSA light and Exclamation sign???
Old 12-07-2009, 06:42 AM
kp4lyfx's Avatar
Exclamation VSA light and Exclamation sign???
So I have a '03 tl-s, and my vsa light stays on and even if i press the vsa button, it won't go off, it's just permanently on. what exactly does vsa stand for and what does it mean for my tl?
Also, there's another light that's on my dashboard that won't go off. It's an exclamation mark inside of a triangle. What does this mean?
Sorry guys, I don't have a manual so I didn't know who to ask except on the best Acura forum ever
Please help me.
Old 12-07-2009, 09:06 AM
rkan121's Avatar
not sure about the vsa light/ button. the exclaimation mark comes on for me when im spining tire, losing tracktion or redlining. im not sure exactly the purpose oh each lights
Old 12-07-2009, 09:12 AM
2000 acura tl FPR
assclown's Avatar
Please help me.
i'm pretty sure vsa stands for vehicle stability assist, and it's some form of traction control, but i don't know much i have a 00' tl-p so i have tcs.
Old 12-07-2009, 09:39 AM
Regional Coordinator (SoCal)
xtremex626's Avatar
Does the exlamation sign and the VSA light stay on together permanently? Or does the exlamation point go away after you turn the ignition off and turn it back on? You should run the codes to determine what the problem is.
Old 12-07-2009, 12:28 PM
philly flickin'
jaMezBOI's Avatar
I recommend taking it to the dealer. This happend to me around the same time my tranny went.
Old 12-07-2009, 03:34 PM
DEPTLS's Avatar
Ditto: this also happened to me before. now before my trans went this was happening and i could not explain it. but everytime i turned my system up loud enough my VSA/Exclamation Sign/Check engine light used to come on. i dunno if you have a system in your car, but that was one factor for me. only when i blasted the music that happened. But it also happened to me when my transmissions from before blew... #5 still going strong!!!
Old 12-07-2009, 05:37 PM
philly flickin'
jaMezBOI's Avatar
god damn, #5!?!?!?
Old 12-08-2009, 03:19 AM
kp4lyfx's Avatar
the exclamation light stays on permanently, the vsa light goes on and off randomly. wow if my tranny goes out, i'm in for a very expensive trip to the shop...
Old 12-08-2009, 11:33 AM
places like aamco or cottman do code reading for free and know what codes are transmission related
parts stores also pull codes for free- report back with those and we can help you more
you could have a bad speed sensor at a wheel too- not everything is trans related!
Old 12-08-2009, 11:34 AM
if its trans on an 03 we can show you how to get help-from acura
Old 12-08-2009, 12:48 PM
B A N N E D
StonedCL's Avatar
where these lights on when you bought the car?
If so BRING IT BACK ASAP!
Old 12-08-2009, 08:22 PM
'03TL-S's Avatar
Does your ABS light come on too?
I have this problem and it's my wheel speed sensor that is stripped. I need to replace this. Anyone knows how hard it is to replace?
Old 12-09-2009, 12:56 AM
Rejckt's Avatar
it really could be a number of things, if all lights are on... your basically in safety mode and anything can throw u in safety mode really... goto autozone and get it scanned. it can be something as simple as sparkplugs, if your tranny is going out usually d5 blinks or you'll feel the slippage.
Old 02-02-2010, 06:39 PM
Distinguish Yourself.
jSoong's Avatar
any updates?
my vsa and the "!" lights have been on and off randomly since yesterday. i checked the manual and it says if this happens, it means the vsa is disabled and you should turn off the car and turn it back on to see if it still appears. it worked the first time, but it still comes on randomly.. the manual says check with an acura mechanic if the lights dont' go away even after an engine restart..
Old 02-02-2010, 07:33 PM
9th Gear
dream54ing's Avatar
How? I want to know...
Old 02-02-2010, 10:33 PM
jSoong- since you are in Ca, parts stores are not allowed to scan codes for you anymore- its smog laws and a way for shops to make money for nothing
Buy a $100 scanner (parts stores still allowed to sell) or check the Meets section of azine for Bay Area events- many of those guys CARRY a scanner to the meets knowing someone will need help
One of them can probably meet up with you and figure out whats wrong
The lights just mean something is wrong- cant tell what without codes- and they are clues not diagnosis
Old 02-02-2010, 10:37 PM
dream- if you are late 03 production and officially `Not covered VIN` on trans extended warranty, you need to know if the recall for oil jet kit was ever installed
Also ask if part of the timing belt pulley recall
register with acura care- 1-800-382-2238x5 and ask those questions then PM me if you are having trans failure issues
for other details see the main Tranny Failure thread and `Goodwill`
Old 08-15-2017, 07:16 PM
Heavyd2099's Avatar
hey guys,
i have the same problem with my 2005 Acura TL. The VSA, (ABS) and (!) lights are all on. They checked with a scanner and there was no codes. Yet the car won't even start. They checked the fuses, they're all good. The checked the wheel sensors, they seem good. They tapped up the brake fluid and it still won't start. Any suggestions???
Old 08-15-2017, 07:26 PM
Skirmich's Avatar
^^ You might wanna try the 3G TL Forum https://acurazine.com/forums/third-g...-2004-2008-93/.
This is a 2G TL Forum 1999-2003.
"They checked with a scanner and there was no codes. Yet the car won't even start"
This would lead me to the TRS but that would trigger an OBDII Code, Ignition Switch? Faulty Key Sensor maybe?
cycdaniel
12-17-2019 10:58 AM
hedzup
1G RL (1996-2004)
06-29-2016 08:07 AM
CheeseyPoofs McNut
10-11-2015 11:25 AM
bryan zaragoza
09-08-2015 12:28 AM
Quick Reply: VSA light and Exclamation sign???
