How to reset check engine light
Old 12-21-2005, 08:31 PM
progz's Avatar
Hi guys...I'm back from hibernation. I had my TCS and check engine light lit and I thought my tranny is going bad. It turned out one of my ignition coil is dead. Now, I need to know how to reset the check engine light. Tried, to do a quick search but nothing came out. Please help.
Old 12-21-2005, 08:48 PM
Did you get the problem fixed?
You can either pull the fuse for the ecu or disconect the battery.
Old 12-21-2005, 09:50 PM
USDM -> JDM
AZN.M3NACE's Avatar
what u do is:
1. TURN OFF IGNITION
2. HOLD SELECT AND RESET BUTTON FOR 10SECONDS
3. TURN ON TO IGNITION II AND KEEP HOLD OF SELECT AND RESET BUTTONS TILL CHECK ENGINE LIGHT TURNS OFF
4. WHEN LIGHT TURNS OFF, TURN ON THE CAR AND SEE IF ITS OFF
Angelstud777 (04-13-2020)
Old 12-21-2005, 09:58 PM
Originally Posted by AZN.M3NACE
what u do is:
Thats for the Maintance required light. Not the check engine light
The following 2 users liked this post by fsttyms1:
Angelstud777 (04-13-2020), Davius (04-06-2021)
Old 12-21-2005, 10:00 PM
Dragging knees in
Pure Adrenaline's Avatar
Disconnect the battery for a while. That'll clear the code(s). But if it's active, it'll come back on again.
Acura TL Builder (04-16-2021)
Old 12-21-2005, 10:21 PM
USDM -> JDM
AZN.M3NACE's Avatar
that should work.... im very possitive
Old 12-21-2005, 10:49 PM
Dragging knees in
Nope, that method will not reset the Malfunction Indicator Lamp.
The MIL has to be reset by using an OBD-II scanner, or by disconnecting the battery.
Old 12-22-2005, 02:45 AM
05 C230K & 09 135i 6MT
03CoupeV6's Avatar
what u do is:
Why not read the thread a little more carefully next time. But to your credit, those instructions ARE correct for resetting the maintenance required indicator.
NOT the same thing as the CEL, though.
Old 12-22-2005, 01:27 PM
progz's Avatar
Thanks for the info guys. Last night when I started my car, the check engine light was gone for some reason. Maybe the computer figured out that the problem was fixed already. BTW, the problem was one of the cylinder was misfiring and it turned out to be the 4th spark plug coil is deffective. Got it replaced and it's good again. It happened yesterday morning on my way to work and I can feel the shake in the engine and then after a few miles, my TCS and check engine lit. Went to get it diagnosed. Dealer wants $90... a friend of mine referred me to a shop for $50. I was hesistant in the beginning because I keep reading in this forum that I can just go to Auto Zone to get it tested for free but my mechanic friend told me to go to the shop to get it diagnosed and a the same time get the actual problem. I forgot the code but the tech showed me the test equipment and it says in the description, MISFIRING. Paid for $47 for the parts.
Old 04-06-2021, 04:30 PM
Michael West's Avatar
How to reset engine light on my 2007 Acura TL type? Someone please help I'm dying
Nothing seems to be wrong with the car. It has no problems at all. I mean I just had a tuneup and diagnostic test and wheels rotated,new alternator I believe that's why it came on to start with but after I put it in it still comes on every day. Guys help please
This is my car it's the type s 2007 TL I don't know if that make a difference or what but someone help
Old 04-06-2021, 04:46 PM
Received 1,736 Likes on 1,392 Posts
Go to a local Autozone, have them read the code(s) for free. Write the codes down so that you can google search to see what's going on if it is something other than the new alternator.
Old 04-06-2021, 05:36 PM
USAF Veteran
Saudade's Avatar
After you get the codes, try posting in the 3G TL forum here:
https://acurazine.com/forums/third-g...-2004-2008-93/
Good luck!!
The following 2 users liked this post by Saudade:
Davius (04-06-2021), whitetiger5 (04-07-2021)
dhmolson
04-06-2021 03:55 PM
99TL-PNBP
05-08-2007 12:32 PM
nam
10-26-2006 02:28 PM
jleon2516
02-13-2005 12:05 PM
ChrisKelly5
06-25-2003 11:41 PM
Quick Reply: How to reset check engine light
