Resetting ECU makes me happy :)
Old 05-28-2010, 04:50 PM
  #201
I'm Craig
cjTL's Avatar
Originally Posted by TeknoKing
Oh goodie! Please tell us more!
...the car goes vroom vroom.
Old 05-28-2010, 06:04 PM
  #202
Onyx97's Avatar
I did it yesterday and it does make a big difference in the cars response.
Old 05-30-2010, 11:31 AM
  #203
Still Lovin my 06
bradykp's Avatar
Originally Posted by BukvaMan
turn the key to the second position make sure everything is off like radio ac and so on... take it out put it back in and then again to the second position and press the gas pedal for like 30 seconds... i do it for a minute just to make sure. Then simply turn of take the key out put it in and turn the car on and there you go
im sure i put couple of extra steps that maybe are not needed but im just making sure i do it right
works everytime
does a similar process work for the 2006 TSX by any chance?
Old 05-30-2010, 07:29 PM
  #204
tnassisi's Avatar
i'll try this on an 09 with push button start by not holding my foot on the brake to keep it from starting.
Old 05-31-2010, 07:22 PM
  #205
REDOO2000's Avatar
subscibed
Old 06-01-2010, 12:51 PM
  #206
flowgoode's Avatar
I didn't read all 6 pages of replies...only the first 2. I believe this does work like people say it does. And then the others that said it doesn't it probably didn't.
All it is doing is resetting your driving habits memory. The drive by wire system adapted to your foot and tried conserving gas mileage by using a little less power with the amout of pressure you're pushing on the pedal.
By resetting that, you go back to the factory setting of the thorttlebody blade opening much more per whatever measurement of pressure your putting your foot down.
You aren't gaining anymore power, you are just utilizing it much better (and decreasing your gas mileage) my
Old 06-01-2010, 03:45 PM
  #207
BukvaMan's Avatar
Nobody said anything about getting more power... or was concerned about losing gas mileage, they wouldn't be looking for the car to be responsive in the first place.
After couple of weeks, every time i do it i see the difference. The car becomes more peppy and more awake. Like the way you would on a high dose of caffeine
Old 06-01-2010, 07:20 PM
  #208
flowgoode's Avatar
Really? Here are a couple people expecting more power and was dissapointed or didnt see how doing this would get more power...hence my explaination of not actually getting any more "power"...
Originally Posted by CL-S progression 01
i'm not trying to kill this thread or take ANYTHING away from you guyz who've had success with this reset business. It just has no effect on mine. with power or shifting.
Originally Posted by 88hybrid
It is nowhere in the FSM, I think its a placebo working in everyones heads!!
From what ive read it seems as if the memory is more like a rolling average. The computer is constantly changing the setting as the car is driven. I dont see how resetting the throttle pedal is going to cause an increase in power.
and quite a few interested in MPG changes...
Originally Posted by pwr2panda
I only noticed a minimal improvement of throttle response...but that could be cuz i drive like a granny. I did notice a definite decrease in mileage tho...23.5 to 20.5. Hopefully it gets better.
Originally Posted by shooter
Anyone notice the MPG diff. after the ECU reset? Just curious ...
Originally Posted by ladiesman217
obv there is a downfall to this almost certain loss of mpg
Old 07-13-2010, 11:40 AM
  #209
08 MDX, 04 TL (sold)
jhumbo's Avatar
Does anyone know if the ECU takes "Driver 1" and "Driver 2" into account? My wife and I both drive the car and I hope her driving style isn't getting blended in with mine.
Old 07-13-2010, 04:46 PM
  #210
Waltah's Avatar
07 tl-s here didn't notice much. I'll re-evaluate on my drive in to work in the a.m
Old 07-13-2010, 05:41 PM
  #211
sixsixfour's Avatar
it only works for the 5AT. MT cars seem unaffected as you shift for the car.
Old 07-22-2010, 11:49 PM
  #212
jpk7's Avatar
My first thought was hey this sounds like the old nintendo cheat codes, but I gave it a try. Throttle is more responsive. Oddly though my fob were no longer synced afterwards, says I have to reconnect. Did this happen to anyone else?
Old 07-24-2010, 11:43 AM
  #213
Xpditor's Avatar
Not to me.
Old 07-24-2010, 12:06 PM
  #214
BANNED
SharksBreath's Avatar
just read the thread, just tried it on my 07 type-s AT, didn't notice anything.
still on the fence about this one...not liking the different responses, "yeah this works", "no it doesn't work"...so idk...i personally didn't feel any difference and i followed the instructions to a T. oh well...only took up 3 mins of my time.
Old 07-25-2010, 07:30 AM
  #215
Craigster05's Avatar
This is correct. The only benefit for an MT is if say the driver was using regular or 87 octane () and finally decided to use premium as they should. The reset will clear the learned timing retard to prevent knock and open up some performance.
Old 07-25-2010, 10:19 PM
  #216
Inaccurate's Avatar
That is a good point. However, the reset procedure discussed in this thread would not make the ecu to relearn the knock retard. To make the ecu to relearn the knock retard, this would require resetting the entire ecu via a battery (or fuse) disconnect.
Old 07-26-2010, 12:12 AM
  #217
kthai417's Avatar
i just bought an 04 ATL....gonna try this out
Old 07-26-2010, 12:14 AM
  #218
I'm Craig
cjTL's Avatar
I thought you were calling him a retard for a second.
Old 07-26-2010, 06:56 AM
  #219
Inaccurate's Avatar
No.... I wouldn't do that
You are too advanced
Old 07-26-2010, 10:21 AM
  #220
murph145's Avatar
tried this before went to work this morning not sure exactly.... i think it feels more responsive but not sure if it is in my mind haha.... i usually drive my car 50 miles a day to and from work mainly highway cruising and it had felt like i lost some of that pick up and go when i floor it... seemed like that was back... ill have to try a lil more when i go home today after work
Old 09-15-2010, 10:25 PM
  #221
ScoobyZINE
AMUA6's Avatar
Revival FTW, will be doing this in the AM
Old 10-05-2010, 07:41 AM
  #222
pastaVTEC's Avatar
FWIW- just tried it on my '07 Type-S 6MT & didn't notice any difference.
Old 10-05-2010, 08:33 AM
  #223
2004 NBP TL 6MT
HondaFan81's Avatar
I have an 04 TL 6MT, bought it some months ago with 66,500 miles. I learned of this Throttle Body Reset Procedure (for DBW vehicles) through this forum before I even purchased the car.
I drove the car from MN to MI some 700+ miles without resetting and partial throttle was alright, but not as responsive as I thought. WOT was fine.
Few days after being home, I remember this procedure and did it out of curiosity being the new owner and the system not having adapted to my driving style. There was a noticeable change in partial throttle response. Since then under partial throttle the TL responds to my driving style better and that from a stop acceleration is smooth. Previously, it was jerky because it lagged on the accelerator pedal from a stop and through off my clutch/accelerator pedal sychronization. Made me look somewhat of a rookie, when I've driven manual Hondas for a long time.
So if you recently purchased your car or have never done this, try it. It DOES work for 6MT as well. Technically, you should only need to do this once, since it does adapt to your driving style and if you do not accelerate hard consistently, then partial throttle will be less responsive to accomodate.
Old 10-05-2010, 12:08 PM
  #224
Disbe's Avatar
I didnt read this while thread and will later but I would assume it has something to do with our cars being drive by wire. I know there is some threads talking about a drive by wire bypass or something that gives you the kind of acceleration you really want. Ill read up and post more when I get home.
Old 10-10-2010, 10:34 AM
  #225
ScoobyZINE
AMUA6's Avatar
I just did my 105K service last night and put on a lightweight pulley. I haven't driven the car yet except around the block. I'm gonna do a full reset by disconnecting the battery for a few, just to make my head big by making me think I gained a shit ton of power
Old 10-12-2010, 07:08 PM
  #226
snake212's Avatar
i can add to this that the car is definitely more responsive after the 5 second method.
Old 10-12-2010, 07:14 PM
  #227
Dan1629's Avatar
I am the biggest fan of this, every time I do it the car is off the hook. I notice a big difference in performance.
Old 02-14-2011, 07:58 AM
  #228
P_R_N_D's Avatar
I noticed it holds gears longer after reset. Don't think I like it...
Also noticed trip comp reset to all zeros. Could use that as an indicator for all the nay sayers.
Old 02-14-2011, 02:38 PM
  #229
jwr0ng626's Avatar
^thanks for bumping! I will try on my way home afterschool!!
Old 02-14-2011, 10:14 PM
  #230
paperboy42190's Avatar
im gonna try this on my 07 tl-s. car drives great but i guess trying this wont hurt.
Old 02-14-2011, 10:34 PM
  #231
'That's what she said!'
renedcruz's Avatar
This is pretty interesting...
Does anyone know if this works on a 1st gen TSX? I would love to try this, if it actually works on the TSX...
Old 02-14-2011, 11:21 PM
  #232
jwr0ng626's Avatar
my trips didnt reset?
Old 02-15-2011, 11:24 AM
  #233
P_R_N_D's Avatar
are you sure the ECU reset though?
Old 02-15-2011, 03:45 PM
  #234
jwr0ng626's Avatar
is it suppose to reset the trip? Not sure if it resetted
Old 02-15-2011, 08:33 PM
  #235
P_R_N_D's Avatar
I don't know if its supposed to. I was just saying what I observed on my car.
Maybe its just the type s or something. They are very different cars on many levels.
Sorry dude. Keep trying it. Couldn't hurt...
Old 02-15-2011, 09:12 PM
  #236
jwr0ng626's Avatar
Lol I tried it again today... I drive under 2.5k on the daily anyways, so when I pushed it AFTER "resetting ECU".. i wouldnt have anything to compare it to haha owell..
Old 02-15-2011, 09:14 PM
  #237
Boosted Life
ch1zo's Avatar
I tried it yesterday and wow I felt a difference.
07 type s for those who say it didnt, I tried the 5 second one.
Old 02-15-2011, 10:28 PM
  #238
Soltex05's Avatar
sorry i am an idiot START POSITION LIKE IT SAYS I AND II so like like the first one right??
Old 02-16-2011, 02:12 AM
  #239
loc05tl's Avatar
haha its 12 AM and i just did a reset on my ecu , then went for a "spirited" ride , haha like a maniac i stepped on the gas till Vtec kicks in. It was pretty awesome. I did the 5sec-2 min reset , but i stepped on it for 7 not 5, just to be sure. When i started the car, it idled a little different but after 3-5 seconds went back to normal. pedal did feel a little touchy than before, but not as much as i expected according to everyone else. Then took it to the street and flored the gas, vtec kicked in a lot faster. response a little better too. Basically it felt like the car just shook off all the rust and took a redbull. I'll wait till a week later to try the other reset method. btw would this kind of ECU resetting work for getting the car used to weather change and stuff too ?
Old 02-16-2011, 03:01 AM
  #240
i tried it today but didnt notice any difference. i have a 2007 tl-s auto.
Quick Reply: Resetting ECU makes me happy :)
