I-169 DIY- Install 6" Headrest Monitors
Old 09-25-2010, 11:22 PM
1islandparadise's Avatar
Well sorry for the long wait from my previous thread but here is the write up. If you all have any questions, feel free to ask!~ I pm'ed "mmade22" a few times with a few questions before I started. Thanks in advance "mmade22", the install came out great!! Below is his DIY thread also which is a MUST READ!
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/diy-install-two-5-6-inch-monitors-headrest-631884/
Inventory:
*New 07-08 Type-S Headrests off Ebay...$115 shipped
*6" monitors off Ebay...$45 shipped
*Clarion Video Amp off Ebay....$30 shipped
*Video RCA cables (yellow) off Ebay...$10 shipped
*Soldering Iron and Solder off Ebay....$3 (OPTIONAL)
*Heat shrink tubing off Ebay.....$3....(OPTIONAL)
*4 front seat back clips from Acura.....$10.49
Tools needed:
*Dremel tool
*10mm socket/wrench
*Exacto knife
*Masking Tape
*Scotch Tape
*Styrofoam
*Pen/marker (Red, blue, black ink)
I traced a piece of styrofoam with a red ink pen and cut it to the size of the monitor.....VERY EASY.....
NEXT 2 photos show the scotch tape used to stick onto the syrofoam. I flipped the scotch tape so it would be sticky on both sides....TOO EASY.....
Place "tape side down" onto the back of the first headrest....CAKE EASY.....
Preparing for the operation!~....scary but believe me...IT IS EASY...Take your time....
Cut an "X" into the center of the headrest. Leave AT LEAST 1/4" from the corners of the masking tape. I made a small "X" and slowly worked slowly to the corners of the masking tape....
Carefully cut the "triangle edges" off the "X" you cut and slowly work towards the edges....takes a little patience but still....EASY AS PIE....
These metal bars are located about an 1" into cutting into the headrests....I dont know what they are for, but I cut them out with my dremel. THIS DOES NOT AFFECT THE TILTING FEATURE IN OUR HEADRESTS!!
This is the metal piece I cut out with my dremel....
This is how you run the wires down the factory headrests.....
**THIS IS OPTIONAL (NEXT 2 PHOTOS)** My monitors were not make to go down a factory headrest pole so I had to cut the connectors and extend them out. This is where I used my soldering iron and heat shrink. If you but monitors that have small connectors, they will fit down our factory headrests....
Make sure you purchase 4 front seat back clips from an Acura or Honda dealership. They are located at the bottom of the seat back and few inches inward. Pull the bottom of the seat back SLOWLY towards you and it will pop off. SLIDE the seat back UP and to remove. As stated in "mmade22" thread these are made to break. I took a flat tip screwdriver and hammer to break mine. Checkout his thread for a more in depth picture.
I unbolted the front seats to get to the factory ground to ground the monitor.
Factory ground located under the front seat.
I placed my Clarion Video Amplifier in the trunk. I have a Navtool also so I used the "Video out" from the Video amp to go into my Navtool's "Video in" and each video out into the video in on the headrest monitors.
I used fuse #32 to this mini-power block to get power for my headrest monitors.
THAT'S IT!!! I was trying to be in depth as possible without being to confusing. This is my first time installing monitors in the factory headrests. I talked to Msala524 awhile back and he made a great point on how "thick" our headrests are and that "cheap" replacement headrests are not thick enough to "use" as headrests. I tried a set of aftermarket 9" headrest monitors and they were far too thin and uncomfortable. I hope this helps anyone that have thought of doing this!~~
AFTER PICS.....
Picture from outside with my "Type-S" 3rd brake light...courtesy of Acktl05)
My Red LED interior....
Old 09-25-2010, 11:30 PM
rossv1's Avatar
Looks Great!
Old 09-25-2010, 11:47 PM
^^^Thanks....have you started on your headlights yet? This is next on my list....
Old 09-26-2010, 12:04 AM
rossv1's Avatar
Not yet. I'm going to do them either this Sat. or Sun. Hopefully.
Old 09-26-2010, 03:31 PM
under renovations....
CubanLynx84's Avatar
great write-up!! everything looks good. I read here somewhere that 7" alpine monitors can fit too in the headrests. I think jptl04 has them. either way the is a perfect diy. I'm gonna be doing my audio/video hopefully next year and this is on my list.
Old 09-26-2010, 05:31 PM
^^^Thanks!~ Yes, there are a few members with 7" alpine monitors while I was doing my research. Msala524 has a set for sale with Type-S headrests.
Old 09-26-2010, 05:53 PM
turbocivic94's Avatar
Looks awsome. Very detailed DIY
Old 09-26-2010, 06:33 PM
^^^Thanks man...I'm just glad to finally have it finished and to move onto another project.
Old 09-26-2010, 07:57 PM
Bone stock tl-s
jptl04's Avatar
Nice install looks clean. Props
Cubanlynx84 is right I do have 7" monitors, they are ness wide screen. But I have them installed in my visors. Great picture and thin enough For the visors.
Old 09-26-2010, 08:09 PM
^^^Thanks!! Just out of curiosity how hard is it to remove the the pillars in the corner to run the wires for monitors in our visors? I read that there are air bag sensors there?
Old 09-27-2010, 05:00 AM
Bone stock tl-s
jptl04's Avatar
Super easy, just pop off the small square pin that has the "airbag" writing. A small flat head screwdriver works, then just pull the pillar off. It won't set off anything I've done it plenty of times.
To run the wires for the visor monitors is kinda hard. Cuz I had to run video and power through the mounting bracket. And the hole is tiny. But it's the best way to do it. Very clean looking.
Old 09-27-2010, 06:25 AM
Thanks for the pics. Sounds easy enought and the install looks great, although trying to fit an RCA cable through that tight corner on the visor looks like it may need a special trick to get it to fit.....
Old 09-28-2010, 11:32 AM
I'm coming to cali to car jack you lol!!!!
Old 09-28-2010, 12:04 PM
Bone stock tl-s
jptl04's Avatar
Ha,ha! Try it buddy! Lol!
Old 09-28-2010, 12:27 PM
don't tempt me lol
Old 09-28-2010, 06:53 PM
jbond2099's Avatar
have the screens ever fallen out, of the headrest
Old 09-28-2010, 08:08 PM
Fear and Loathing in my
Timb227's Avatar
Nice, and it looks fairly simple. Good Job!
Old 09-28-2010, 08:19 PM
I forgot to mention I put glue behind the frame the monitor sits in and pressed them into the headrest.
Old 10-04-2010, 06:51 PM
NvMySi's Avatar
very nice install my kids would definately love this in the back. and would keep them quiet lol.. thanks for the info.
Old 10-11-2010, 04:55 PM
NvMySi's Avatar
just wanted to know where to get a cheap dvd player to get the screens working? am going to try this DIY over winter this year.
Old 10-11-2010, 05:57 PM
Before you start this project I highly recommend researching throughout the forum because this is a pretty big task, but more than doable. I picked up my DVD player from Ebay for $78. You will also need a Navtool, Dom's unit, or something similar. I would checkout ebay or amazon. Just know that, not any DVD player will fit in the center compartment. Smaller the better. Here are a list of threads I saved before I started this project. If you need any assistance, feel free to shoot me a PM...
DVD/Navtool info
https://acurazine.com/forums/showthr...=784330&page=2
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/08-tl-type-s-dvd-nav-conversion-776073/
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/rockyfellers-dash-myron-davis-dvd-doms-unit-p-i-e-x3-wendys-camera-install-622410/
Headrest monitor Info
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/2008-tl-type-s-headrest-monitors-715773/
https://acurazine.com/forums/showthread.php?t=631884
Old 10-23-2010, 04:22 PM
zain22150's Avatar
quick question would 7inch monitors fit in those headrests?
Old 10-23-2010, 09:08 PM
Yes it will. msala524 has a set of 7" alpine screens in his Type-S headrests for sale now. I chose 6" because I found these for $45 on ebay.
Old 10-28-2010, 12:40 AM
06TLCROMIE's Avatar
looks awesome.. didnt look to hard for a DIY!
robm
09-18-2015 07:53 AM
TxRzrBk
09-17-2015 01:07 PM
PortlandRL
09-14-2015 12:01 PM
iRaw
ILX
09-05-2015 12:10 AM
kareshi
09-03-2015 03:38 PM
Quick Reply: I-169 DIY- Install 6" Headrest Monitors
