swoosh's build thread....the HIGH PROTEIN DIET !!! (Updated Pics-Page 74-7/12/15)
Old 04-17-2012, 12:40 PM
  #361
gerzand's Avatar
Hammering throttle all night around town.... 29mpg. Have yet to see what it can do highway, since im always...............hammering the throttle, lol
Old 04-17-2012, 01:09 PM
  #362
takin care of Business in
swoosh's Avatar
how is your knock over 4500 rpm ? whatcha do to fix it ?
and Feji you bastid....i just thought will delay the braille battery as am spending a lot and you come along and make me spend more
let me call around
Old 04-17-2012, 01:12 PM
  #363
rockstar143's Avatar
Gerzand, you have got to be kidding me...getting to PUNCH IT, make more power AND get 29MPG just blows my mind.
Old 04-17-2012, 01:14 PM
  #364
gerzand's Avatar
Race gas...102 octane (mixed). We've got it cheap around here. 6.25/gal for 110
Old 04-17-2012, 01:15 PM
  #365
FCVadi's Avatar
gerzand, how lopey is your TL? you are running camshaft grinds either stage 2 or 3?
on a side note, (to others as well) how in the world do you explain lopey? I have seen it but I could never find the words
Old 04-17-2012, 01:21 PM
  #366
gerzand's Avatar
I'm on "Stage II's"
Regarding "Stage III"...none are currently out there (advertised for sale) unless you grind to your own specs
Aside from describing the sound, from a mechanical standpoint lope is when intake valves are still open when piston is at BDC and exhaust valves are open as well, thus letting a small amount of gases escape into the intake tract
Old 04-17-2012, 01:47 PM
  #367
is lopey that crazy sound you'd hear from old mustangs with an E303 cam or whatever it was that would make it sound like it was idling so rough that it sounded like it was about to shut off?
Old 04-17-2012, 02:18 PM
  #368
swoosh's Avatar
^^^ yes....you should check some of Andy's videos of his Base....you will see how lopey that was....
and Andy....that is not bad at all.....i cant wait to get my heads done....
Old 04-17-2012, 02:21 PM
  #369
gerzand's Avatar
There are varying degrees of lope, but I would categorize my lope as relatively mild. An "agressive lope" would be a 275 or higher duration cam. As you Refer to, the "303" in your "E303 cam" describes the degrees of rotation for which the intake valves are open. That is bordering insanity because it can result in substantial loss of compression at idle or even low rpm's because it is not until mid/high rpm's that the loss of exhaust gases can be outweighed by benefits tp to the combustion process by A) a more efficient evacuation of the combustion chanber of carbon monoxide which improve combustion efficiency, and B) Leaving intake valves open longer as to take in more oxygen, equaling more high end horsepower.
Old 04-17-2012, 02:23 PM
  #370
swoosh's Avatar
^^^ and your low end goes out of the window....
Old 04-18-2012, 01:42 PM
  #371
swoosh's Avatar
ok people....
i am thinking of going with 500cc injectors....with the new manifold + TB + intake i think i would need bigger injectors....RDX would do fine but thinking of 500cc injectors....
what is a good company that makes injectors ? looking for high atomization as well as a good flow design....any opinions/options for me ?
so should i shuddup and stick with the RDX injectors
also someone know the injector size for the Shawd TL/MDX/RL ???
Old 04-18-2012, 02:01 PM
  #372
FCVadi's Avatar
RDX has the biggest but that is because of the turbo
take teh dag on car out first with the 410cc before getting 500cc.. tune then see...
swoosh (04-18-2012)
Old 04-18-2012, 02:08 PM
  #373
swoosh's Avatar
Great advice buddy....
Thanks and will stick to RDX injectors !!!
Old 04-18-2012, 02:11 PM
  #374
I could have sworn someone wrote that there were an alternative to the RDX ones that were bigger and cheaper that worked?!?! Can't remember what thread.
Andy, thanks for the response...my head is spinning. I don't know about losing low end on a fox body mustang, but I do know my buddy broke into the 11's on that one.
Old 04-18-2012, 02:19 PM
  #375
swoosh's Avatar
^^^ Jer...if you find the thread lemme know
Feji,
how is the atomization quality of the RDX injector....if am paying that much might make sure that is the best injector money can buy....
Old 04-18-2012, 02:27 PM
  #376
could it be the PNP Andy one?!?! I'm trying to recall...it was recent...or the ECU one?
Old 04-18-2012, 02:29 PM
  #377
swoosh's Avatar
^^^ you just mentioned 6 threads which are 20+ pages on an average
Old 04-18-2012, 03:00 PM
  #378
#1 Super Guy!
94eg!'s Avatar
That was me. It was Injector Dyanmics. These are Bosch's latest technology performance injectors built upon/after the RDX technology. They are big (725cc and up) but ID2000's have been shown to idle a stock LS integra no problem. All motor guys are using them on applications that call for a 310cc and making power over RC's.
http://www.injectordynamics.com/
Here is a Honda-Tech seller, but you have to PM for shipped prices.
http://marketplace.honda-tech.com/sh....php?t=2802588
Also, Xenocron Tuning sells them: http://www.xenocron.com/injectors-c-...775436883229d7
rockstar143 (04-18-2012)
Old 04-18-2012, 04:07 PM
  #379
swoosh's Avatar
^^^ let me look into those and see what happens....
94eg! just when i make my mind you come confuse me brah !!!
Old 04-18-2012, 04:44 PM
  #380
FCVadi's Avatar
Feji,
so first by atomization I am going to guess you mean spray pattern
i have no personal experience, and none of my friends around here do either.. (on a side note most of my friends think I am crazy.. they are the type that will just add wheels or tint to their cars and call it a day)
I have researched and I have the following
http://www.onecamonly.com/archive/index.php/t-1895.html
here is a youtube from that thread
also this one:
its a DIY but good research
http://www.8thcivic.com/forums/do-yo...r-install.html
and thirdly
http://www.nsxprime.com/forum/showthread.php?t=157469
I have a few more but everything I read says RDX has one of the better spray patterns out there for the money... i did a bit of homework before I gave my lunch money for it
but it is folks opinions, I havent heard anything negative but no concrete data #s on anything.. even though a few civic, RSX, and integra turbo users do get them i still do not have any dyno info.. but I guess I will this summer
now if you go turbo and want over 450hp then you might need something bigger but I have not reasearched into all that is neede for turbo.. for N/A this is what I am figuring I would need in my endeavor to go Ricky Bobby
swoosh (04-18-2012)
Old 04-18-2012, 06:37 PM
  #381
swoosh's Avatar
FAWKING awesome info there Feji....I will be sticking to RDX injectors.....
94eg! i looked into Injector Dynamics and damn the 725cc are expensive....
also WOW they tooo big for my needs.....
^^^ thats what she said
Old 04-18-2012, 08:10 PM
  #382
...wait, SHE said that to you!?!?
94, thanks for chiming in, when I saw your response I knew immediately it was you that had said it (obviously).
Old 04-18-2012, 08:57 PM
  #383
#1 Super Guy!
94eg!'s Avatar
No prob.
I was gonna add that if money was no object, then ID725's would be the way to go. But the last time I checked, RDX-410's were less than half the price. Kinda makes makes for a no-brainer for us average Joe's. Personally I wish I coiuld justify giving RDX's a try on my Civic/B18C. But the added cost of fuel rail adapters, pigtails and a dyno tune to bring out their max potential are not really in the cards for me any time soon.
It's okay, I drive like a grandma anyways. lol
Old 04-18-2012, 09:20 PM
  #384
swoosh's Avatar
I know Rodney is selling the RDX injectors + pigtails for $400 shipped
during the GB they were around 350-360 shipped....let me know if you need a set
94eg! (04-18-2012)
Old 04-18-2012, 11:11 PM
  #385
#1 Super Guy!
94eg!'s Avatar
LOL! That's not even close to a good deal. RDX injectors 16450-RWC-A01 only cost $39 each from the online Acura dealers. The pigtails can't cost more than $40 for brand new set of 4. I hope you guys weren't getting screwed!
http://www.oemacuraparts.com/index.p...A01&make=Acura
The following 3 users liked this post by 94eg!:
civicdrivr (04-18-2012), justnspace (04-18-2012), swoosh (04-19-2012)
Old 04-18-2012, 11:38 PM
  #386
Teehee.
Old 04-18-2012, 11:54 PM
  #387
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,144 Likes on 4,811 Posts
I got my set with pigtails for $230 shipped.
Old 04-19-2012, 01:18 AM
  #388
Hacura's Avatar
Swoosh, just get the injector dynamics cause we all know you'll want moar and end up spending extra by going the RDX route first.
Old 04-19-2012, 07:32 AM
  #389
FCVadi's Avatar
i did the math on the cost for injectors and pigtails and they break even from Rodney for the GB.. the one thing to note is that it should be plug and play (meaning still tuning but no cutting).. i also put a $ value on my time being spent cutting/modding stuff to make it fit... i always do the math before i give my lunch money to someone... and the funny part is I am bringing my lunch (brown bagging) to work all this week
swoosh (04-19-2012)
Old 04-19-2012, 09:39 AM
  #390
swoosh's Avatar
i used the wrong word i think....
$400 shipped was for injectors
($40 a pop X 6 = $240)
and i said pigtails where i meant pnp harness
($20 a pop x 6 = $120)
total comes to $360 which i think was the GB price....you will not need to splice any harness or cut any wires....pnp....if you get the scion TC clips and the pigtails you will spend ~$50-60 and then do DIY on em....
Teehee.
from where
hahhaha i know right.....but yeah i doubt i will every push more than 400whp (350 would be nice) and hence i might save some $$$ and stick with RDX ones....
^^^ THIS
thanks Feji....yeah there was miscommunication from my part earlier.....thanks for clarifying.....
Old 04-19-2012, 09:43 AM
  #391
FCVadi's Avatar
I am curious where civicdr got his with pigtails fro $230.. was that for 4 or 6? I think I seen pacakge deals for 4 around that price.. all the hours/days of surfing is becoming a blur
Old 04-19-2012, 09:46 AM
  #392
swoosh's Avatar
^^^ yeah i think he has a little I-4 engine
Old 04-19-2012, 10:15 AM
  #393
#1 Super Guy!
94eg!'s Avatar
The ID's will make more power no matter what your putting down because of better fuel atomization. Plus having a "matched" set along with all the dead-time, voltage flows & other specs help the tuner really dial them in. A big all-motor 4-cyl build on Honda-Tech was "claiming" 25whp over RC's just from switching & re-tuning. Of course RDX's will out perform RC's as well, and they are still a way better deal ($$$ per hp) over the ID's.
And what's all this P&P harness nonsense. Don't be pansies. I don't bill myself for my own time having fun with a hobby, and you guys shouldn't either. lol
civicdrivr (04-19-2012)
Old 04-19-2012, 10:18 AM
  #394
FCVadi's Avatar
my wife bills my time
Old 04-19-2012, 10:43 AM
  #395
#1 Super Guy!
94eg!'s Avatar
Mine too. But I fudge the numbers.
Old 04-19-2012, 11:39 AM
  #396
FCVadi's Avatar
nice! I havent gotten there yet, working on the not getting caught part of the plan
Old 04-19-2012, 12:16 PM
  #397
callahan's Avatar
^haha it's so ture
Old 04-19-2012, 12:21 PM
  #398
civicdrivr's Avatar
They were with the TC pigtails, not a PnP harness. I forget where I got them, it was about 2 years ago. And it was all 6, with o-rings.
Old 04-19-2012, 12:53 PM
  #399
swoosh's Avatar
you guys are funny....
i tell my wife everything and she supports me completely
and yeah i just thought its a good deal (pay 20-40 bucks more) and get everything plug n play)
Old 04-19-2012, 01:04 PM
  #400
I don't want my wife to support me completely...I need someone in my life to tell me when I'm doing something stupid!
Quick Reply: swoosh's build thread....the HIGH PROTEIN DIET !!! (Updated Pics-Page 74-7/12/15)
