Matching Paint Grill
Old 05-25-2010, 01:23 PM
MrOtocinclus's Avatar
OEM grill part #: 71122-TL2-A00
Cost: $150-$200 depending on where you look.
Old 06-15-2010, 05:43 AM
bastircar's Avatar
Originally Posted by nytsxv6'10
havee the palladium metallic and was thinking about painting it flat black...
Originally Posted by thunderbt3
Sort of along the lines of this heh:
Acura competes in what country?
and OT i have same colour (buran silver - in Europe) and because is a diff. colour i prefer to keep the original nickel grid.
one to another...
Old 06-16-2010, 12:23 AM
lightjak_tsx's Avatar
Smile
Originally Posted by MrOtocinclus
I'm really liking this thread, with all those pictures of various grills. I'll add another one, similar to the one I posted above, but with the Aero bumper:
mrotocinculus where did you order your front bumper???
Old 06-16-2010, 08:30 PM
05AcuraTL916's Avatar
Would anyone know where I can get the oem paint or close enough to match my Night Hawk Black paint. I painted mines gloss black but it did not look right since my car is bluish in the sun which throws the black off. Thanks.
Old 06-17-2010, 11:58 AM
scooterb84's Avatar
Honestly, stock has really grown on me.
Old 06-17-2010, 12:09 PM
defconskylude's Avatar
seems like youre going to do a DIY paint job?
yea just go to a local auto body shop and tell them to mix you the OEM paint. they will find the OEM color code and do the paint in house. it should cost you about $60-$75 for the paint itself.
Old 06-18-2010, 03:15 AM
  #47
bastircar's Avatar
u can find the paint code on the door post is an engraved plate under the vin is the color code, tell this code to a auto body shop / some 1 who can mixt and prepare that for u.
good luck!
in many cases this paint wont match100% so ul have to polish all te car after u paint a part, because the sun affects the coat of the paint that "burns" it a bit...
Old 06-18-2010, 11:05 AM
go to your acura dealer and ask them who paints their cars. the shop they refer you to will likely have the closest OEM paint job
Old 06-18-2010, 11:45 AM
  #49
Mademoiselle Chanel!!
compewterbleu's Avatar
Originally Posted by DerwoodEE
Mine's been done since October 2008. No clear bra or anything and it's held up great.
That's str8 nasty...love it, love it, love it.
Old 06-18-2010, 11:50 AM
  #50
Originally Posted by defconskylude
www.stickercity.com its $30 for 12in x 48in
its 3D textured carbon fiber vinyl. 3M di-noc.
make sure to use a heat gun
here's more close ups and angles. i did some eye lids too.
Whoa, looks like you had Lucius Fox from the Dark Knight hook you up! It's different and very unique...covert ops looks...ruthless.
Old 06-18-2010, 11:52 AM
  #51
Originally Posted by baltimorecaesar
I'd rather have the original untouched. Just personal preference.
I'm feeling that too! And I miss the Inner Harbor!
Old 06-18-2010, 08:07 PM
  #52
Thanks for the reply guys, I came across this on one of the threads I found http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT anyone ever tried these before?
Old 08-13-2010, 03:41 PM
  #53
UBNVUSE's Avatar
Where'd you get your headlight protector?
Old 10-31-2010, 05:01 PM
  #54
Midwest TSXer
KingTSX's Avatar
How are you getting the front grill off the car? I need to have the upper grill either painted or replaced. The clear coat is peeling off and the chrome has since started to rust/turn blackish. I can see there are four screws on the backside of the grill looking through the top, but couldn't figure out how to take off the entire grill (if it actually all needs to come off) by looking at it?
Old 10-31-2010, 07:31 PM
  #55
You have to take off the front bumper to remove the grill. Search around for instructions on how to install the Aero bumper, the first few steps show you how to remove the front bumper.
Old 11-04-2010, 03:21 PM
  #56
YPBVP's Avatar
Your front grill
I really like the front grill you have on your car. Any idea where I might be able to get that from?
Old 11-04-2010, 03:40 PM
  #57
09TSXTech's Avatar
If you are looking for the CF grille on MrOtocinclus TSX, it's from CT Engineering:
http://www.ct-engineering.com/store/product1564.html
Old 11-04-2010, 06:05 PM
  #58
or you can spend $25 and wrap the grill in cf vinyl
Old 03-07-2011, 10:41 PM
  #59
llitsjennll's Avatar
i like the carbon fiber on the grille...looks nice.
Old 03-14-2011, 09:35 PM
  #60
pieman's Avatar
100% agree! It looks sweet.
Old 03-14-2011, 09:45 PM
  #61
demetrius82's Avatar
no you dont have to take the bumper off. i took my grill off in 20 mins, pop the hood, pop he pins that hold down the plastic over the grille, lift it up and there are 4 clamps and 2 small screws you have to loosen right near the headlights. go to local home depot and ask for an alen key with a phillips head tip and youll be able to get to the screws without removing the bumber, , under the grille theres 4 more clamps holding the grille behind the grille at the bottom, 2 at the middle and one in each corner of the bottom of the grille, pop those out and grille comes right out. , ill post up instructions with pics
ojasdatt (06-22-2012)
Old 03-14-2011, 10:03 PM
  #62
SeeYou2Crew #2
ed_423's Avatar
^ i believe the plastic cover over the grille you are referring is the radiator cover? someone correct me if i am wrong
Old 05-29-2011, 12:36 AM
  #63
PersianBoi's Avatar
Is there any downside to the carbon fiber wrap? Such as peeling/chipping, or damage once removed? I heard that when the weather gets very hot, they can even melt. Is this true??
Old 05-30-2011, 09:06 AM
  #64
tvac's Avatar
I'd be interested to know the answer to this question as well. Since I really like the all black look I was thinking of using the finished look of the CT Engineering carbon fiber replacement blade with the DiNoc wrap on the trim.
Old 05-30-2011, 09:23 AM
  #65
kowloonsniperhk's Avatar
you could also try water transfer imaging to get the CF look.
google CRC hydrographics. They do water transfer imaging for guns and cars
Old 05-30-2011, 11:21 AM
  #66
PersianBoi's Avatar
click on the link to see how to remove the grille on a 2009-10 tsx.
http://www.carid.com/images/grilles/...ion-manual.pdf
Click in this link to see how to remove the grille on the 2011 model:
Hope this helped!
Old 06-22-2012, 03:46 PM
  #67
2009 TSX
ojasdatt's Avatar
Thx a ton I have the same problem, I am goin to try and remove it over the weekend w/o taking the bumber off
Acura604
2G RDX Photograph Gallery
27
10-08-2020 09:24 PM
iRaw
ILX Photograph Gallery
30
08-05-2016 04:41 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
rhdune16
09-28-2015 11:31 AM
scionxb3003
09-22-2015 05:28 PM
Quick Reply: Matching Paint Grill
