D-100: The Official "Does This Wheel and/or Tire Fit My Car" Thread
Old Nov 20, 2008 | 08:50 PM
  #281
Crow's Avatar
Smile Revised
Originally Posted by Crow
Questions on Wheels
Wheel Make/Model: Axis Penta
Wheel Size (**X**): F:19x8.5 - R:19x9.5
Wheel Offset (+**): F:35-45mm - R40mm
If lowered (amount): None
Questions on Tires
Tire Make/Model:Suggestions?
Width/Sidewall-Diameter (***/**-**):F:245/40-19 - R:255/40-19
Can you guys please help? I'm sorry, but i just came across this thread; if i knew i wouldn't have post a new one asking this same question.I got an 05 TL and I'm thinking about getting Axis Penta 19s (19x8.5F) (19x9.5R) but do not want to go with 30-35 series. Really want to do 40 series, since I've had horrible riding experience with 35s in the past. Does anyone know if this will cause the tires to rub? I don't plan on dropping the TL.
If i can't do this, then I will probably do the 18s" Penta Maxis (fake staggered). Please advise!!!
Got the offset(s)
Old Nov 21, 2008 | 09:46 AM
  #282
stillhere153's Avatar
94 DC4 RS LSV/Turbo
the pentas fit no problem and won't rub... if you want a 40 sidewall you will have to subtract from the width
215/40-19 or 225/40-19 i believe one of the 2 is plausible and the other doesnt exist lol
Old Nov 21, 2008 | 09:48 AM
  #283
94 DC4 RS LSV/Turbo
Originally Posted by horsepowercrzy18
so i test fitted my 20x8.5 with +35 offset and 255 35 20 tires today on my 04 tl 6 speed and the wheel hit the brembos. im just wondering what size spacer you guys think il need to make it work. 3mm or 5mm spacer?
which wheel?
get a handfull of washers measure the thickness in mm (usually washers are 1mm)... put 3 washers on each wheel stud, if it clears then you only need a 3mm, if it doesnt then you won't be able to run this wheel period
as for the tires, you can't run 255/35-20 at all with a wheel with an offset bellow 38 without rubbing
Old Nov 21, 2008 | 09:49 AM
  #284
94 DC4 RS LSV/Turbo
Originally Posted by Babnik
Will the 16" steel rims that the Honda dealership sells for winter tire packages for Accords fit my 04 TL?
if your car is auto yes
Old Nov 21, 2008 | 10:55 AM
  #285
juruki's Avatar
Stillhere153 help me out please. Im about to recieve my Work Varianza T1S and dont know what tire size to use for the rear wheels.
My specs are:
19x8.5 +38 front (planning on getting 235/35/19)
19x9.5 +36 Rear (planning to roll my fenders but dont know tire size)
Im planning to ride pretty low but not slam it. Do i go with a 35 or a 30 series? 265 or stretched 245? For some reason theres not that many tires that are 255.
Old Nov 21, 2008 | 04:25 PM
  #286
Timeless's Avatar
Alright good sir....I'm picking up some 19x8.5's +35 offset. Car will be dropped as low as possible...but as low as possible will be dictated by tire size. Should i expect any issues with this offset if I run 265/30-19's? I understand I won't be able to "slam" it. Mind you I live in New York so we know how the streets are. 255 a better choice?...if i can find them.....
Old Nov 21, 2008 | 07:29 PM
  #287
chuanger's Avatar
One or Two?
I'm planning on getting some AME Shallen FXs, similar to Rodney's setup. I want 19s and i'm only planning to drop the car 1" at most. This is what Rodney suggested for my 08 TL-S..
Front: 19x9.0, +42mm, High Disk Tire: 245/35/19
Rear: 19x9.5, +45mm, Super Low Disk (for max lip?) Tire: 245/35/19 or 255/35/19?
How does this sound? With the offsets listed above, will the wheels sit flush? I don't want them sticking out. Any other advice? Also, is there any advantage to staggering the front/rear wheel sizes other than for cosmetic purposes? Thanks!
Old Nov 21, 2008 | 08:48 PM
  #288
ASASN21's Avatar
Stand For Something
Alright got another one for ya...
Advan Model 5
19x9 +45 All around
245/35/19 FK452s
Clear BBK? Have to roll front fenders?
Old Nov 22, 2008 | 04:03 PM
  #289
94 DC4 RS LSV/Turbo
My specs are:
mmmmh 265 with -2 degree negative camber might be ok, 245 def fits tho
255 if you find it will work also
if you get 255 or 265 you could roll with either the 30 or the 35 sidewall, the 35 will provide a slight more cushioning for your passengers
245/35-19 would be the safest bet (not a stretch at all really)
Old Nov 22, 2008 | 04:04 PM
  #290
94 DC4 RS LSV/Turbo
Advan Model 5
19x9 +45 All around
245/35/19 FK452s
will not require any fender rolling at all, advan's usually are made to clear bbk, this may or may not clear... if it doesn't I would anticipate requiring a 10mm spacer at most
Old Nov 22, 2008 | 04:05 PM
  #291
94 DC4 RS LSV/Turbo
245/35-19 would be your best option since you want to slam... with a +35 anything else will cause your front fenders to chew it up
Old Nov 22, 2008 | 04:06 PM
  #292
94 DC4 RS LSV/Turbo
that'll work rodney knows his stuff, and I'd trust him all the way
Old Nov 22, 2008 | 04:32 PM
  #293
Crow's Avatar
Thanks stillhere!
Will the 225/40-19 fit a 9.5" wide rim? (sorta a big investment to be plausible)
"if you want a 40 sidewall you will have to subtract from the width" -- How does that work?
Should I run all the same size size tires for both the 19x8.5" and 19x9.5"? WHich is... (2??/40-19)
The tire shop and wheel company are saying I NEED to go 245/35-19 or it will rub. Of course I'm sure they are basing it off their computer and trying to match it closest to the stock wheel/tire.
Should i shut up and go 18s?
Old Nov 23, 2008 | 02:59 PM
  #294
wps007's Avatar
will these fit
18x8.5 plus 20 with 245 40 18 tires on the front
19x9.5 plus 45 with 275 35 19 onthe rear
Car sits on Tien SS Coils with A spec Struts
2006 TL with auto
Old Nov 23, 2008 | 03:13 PM
  #295
wps007's Avatar
will these fit
18x 8.5 plus 20 245 40 18 front
19 x 9.5 plus 45 275 35 19 rear
tien ss coils a spec struts
2006 tl auto
Old Nov 23, 2008 | 04:28 PM
  #296
ifirahse's Avatar
SlammedOnKonis
What size sidewalls should I go with?
19x8.5 +35, 245 up front and 255 in the back.
I'm going to be slammed as low as possible.
Old Nov 23, 2008 | 07:46 PM
  #297
94 DC4 RS LSV/Turbo
Thanks stillhere!
here is what I would do if I wanted staggered pentas
19x8.5 +35 (225/40-19)
19x9.5 +40 (255/35-19) if you go 255/40-19 it will look way to thick...
Old Nov 23, 2008 | 07:55 PM
  #298
94 DC4 RS LSV/Turbo
2006 TL with auto
the front will need a 225/45-18
and even then it is pushing it
needs 225/45-18 fronts... might force it to 225/40-18 since your lowered
the rear is fine if you roll the fenders 275 is too thick... try 255/35-19
Old Nov 23, 2008 | 07:59 PM
  #299
94 DC4 RS LSV/Turbo
front is a 35... (245/35-19)
whats the width of the rear, if the rear is 8.5 I would roll with the same on all 4 corners (245/35-19)
but if the rear is wider you can either do a 255/35-19 or a 255/30-19
Old Nov 23, 2008 | 10:35 PM
  #300
wps007's Avatar
will they fit
I want to run a 18 x 8.5 with a plus 20 offset in front with 245 40 18 tires, 19 x 9.5 on the rear with 275 35 tires on a 2006 TL Auto with Apec kit with tien ss coils and Aspec Struts and standard brakes
Old Nov 23, 2008 | 10:38 PM
  #301
wps007's Avatar
I currently am running A spec wheels with the 245 40 18 is it the offset on the new wheels that will give me a problem in the front, Wheels arrive Tuesday
Old Nov 24, 2008 | 05:52 PM
  #302
94 DC4 RS LSV/Turbo
dude read the page i already replied
Old Nov 24, 2008 | 11:12 PM
  #303
enigmaos's Avatar
Too Fast TOO FURIOUS
How about 18x8.5 +20mm with 235/40/18?
Old Nov 25, 2008 | 12:21 PM
  #304
94 DC4 RS LSV/Turbo
225 is as big as you can get in the rear
Fronts if not lower than 1.5" can go up to 245
Old Nov 25, 2008 | 08:39 PM
  #305
wps007's Avatar
Made a mistake on the wheels, The fronts are 18x8.5 35 offset, 245 40 18
Rears are 19x9.5 45 offset 275 30 19 tires, TL has Tein Stech Coils with A Spec struts, Planning to roll the rear if needed
Old Nov 28, 2008 | 05:27 PM
  #306
94 DC4 RS LSV/Turbo
^ sorry I didn't reply sooner, but yeah that is a great fit, def gonna need to roll the rears because it might rub
Old Dec 1, 2008 | 10:11 PM
  #307
milk man's Avatar
yo ? question i have a set of 19s 19x8 30 offset and i my car is slammed kinda haha you know how low it is 2.25 lowered all the way around... what size tires do i need to run with out rubbing front and rear? 215/35 or 225/35
Old Dec 2, 2008 | 09:17 AM
  #308
rodneyc77's Avatar
Retired!!! ON TOP!!!
235/25/19 will do it for you Milk Man all around... and if you're really concerned... do 225/35/19 Front and 235/35/19
Old Dec 2, 2008 | 09:24 AM
  #309
rodneyc77's Avatar
Like I mentioned to you already... they WILL NOT fit flush... in order for them to sit flush... you'll need to modify your fenders, run slimmer tires and push the wheels out -15mm all around...
Your goal was to not do any modifications to the car's fenders and have beefy tires installed for everyday driving...
Do 19x9 +40mm high Disk in the front... and add +2mm of lip
I would suggest you do 245/35/19 tires all around for easy replacement... cause the 255/35/19 are pushing the limits of needing a fender roll in the rear...
Old Dec 2, 2008 | 05:34 PM
  #310
milk man's Avatar
thanks rodneyc77
Old Dec 5, 2008 | 12:50 PM
  #311
ImPoRtHoNdA's Avatar
My username is lame
Questions on Wheels
Wheel Make/Model: ADR M-Classic or M-sport
Wheel Size (**X**): 19x8.5 all around
Wheel Offset (+**): 32 or 35
If lowered (amount): tein s-tech
Questions on Tires
Width/Sidewall-Diameter (***/**-**):considering getting 245/35zr/19 or should i go with 235/35/19?
thanks in advance
Old Dec 5, 2008 | 02:56 PM
  #312
94 DC4 RS LSV/Turbo
Originally Posted by ImPoRtHoNdA
Questions on Wheels
Questions on Tires
thanks in advance
245/35/19 for the +35 offset
235/35/19 for the +32 offset
Old Dec 5, 2008 | 04:51 PM
  #313
265 ssi's Avatar
320 sc
How about 18x8.5 with 35 offset and 255/40-18 all around, I am stock height w/koni. I see that my secound choice 245/40-18 is ok
Old Dec 5, 2008 | 08:47 PM
  #314
My username is lame
i got a 32offset, if i went with the 235/35 i shouldn't have problems with rubbing will i?
Old Dec 5, 2008 | 10:16 PM
  #315
94 DC4 RS LSV/Turbo
correct, no problems you'll be a-o-k
Old Dec 5, 2008 | 10:17 PM
  #316
94 DC4 RS LSV/Turbo
either works no problem
Old Dec 6, 2008 | 03:02 AM
  #317
Paul_2007S's Avatar
Type- (S)low
My turn:
Car: 07 TLS
Enkei Rpf 1
19x8.5 F / R
+42 offsets all
Will i need spacers?
Old Dec 6, 2008 | 08:53 PM
  #318
Adidasboy1186's Avatar
Questions on Wheels
Axis - Shine
F 19-8.5" R 19-9.5"
I believe F +15 R +25 correct me if im wrong.
Ride is stock now, but plan on lowering
Question on Brembo/Big Brake Clearance
I bought these rims for my 350z w/ brembo brakes that i used to have. Havent been able to sell the rims and was wondering if they will fit my 05 TL. I am willing to roll my fenders...
In this link https://acurazine.com/forums/showpos...8&postcount=16
it is said that a 9.5in wide rim (w. according drop) and a +25 offset would like that. That is exactly same size as my rim but i think my tire would look a little bit larger than that, BUT everything fits there... Im jsut trying to save myself the trouble AND money of selling these and buying new rims. Any input would be great appreciated. Thx
Questions on Tires
Kuhmo Ecsta SPT
245-35-R19
275-35-R19
Need a spacer?
I doubt i will need them as im wondering if there too wide with the offset.
Old Dec 6, 2008 | 09:03 PM
  #319
cknwang's Avatar
So now it's my turn to get some new shoes on my 07 Type S. I use it as a commuter car so I'm not really big on spending lots for rims. I was looking at some 18 inch Rota rims. Can anyone let me know if these will fit my ride?
MAKE OF WHEEL: Rota
MODEL OF WHEEL: G Force (Gunmetal)
FRONT SIZE AND OFFSET: 18x8.5in & 48mm
REAR SIZE AND OFFSET: 18x8.5in & 48mm
TPMS YES/NO: Yes
SPACERS YES/NO, WHAT SIZE: None
TIRE SIZE: Any recommendations? I do lots of highway driving so don't want a super soft tire....something that lasts long and has good traction.
Old Dec 6, 2008 | 09:05 PM
  #320
94 DC4 RS LSV/Turbo
Originally Posted by Paul_2007S
My turn:
Car: 07 TLS
Enkei Rpf 1
19x8.5 F / R
+42 offsets all
I think not the spoke design gives plenty of bbk clear
