2003 Acura TL-S cat delete
Hey kinda new here,
I've had my 03 for a while now and it makes pretty good HP, thing is, it doesn't sound as good when I'm reving it, kinda quiet, any way I can delete the cat but replace it just in case? Like a bolt on or something?
Yes for about $20 shipped you can order a test pipe for a 01 Accord V6 off Ebay. You will also want a 90 degree spark de-fouler for the O2 sensor should less than $20 as well.
It will soot up the back of your car and some say that it smells bad.
03 tls nc (10-01-2016)
J35 _ 5 Speed A/T
If the CL-s exhaust system is like the accord, you should just start with removing the "pre-muffler", that will add some exhaust note to it.
A Cat-Delete will make it louder, might add some rasp to it at higher rpm.
Doing both, will be end up being loud. might add some Drone too?
ExcelerateRep
06-20-2022 09:21 PM
