Dash Lights Do Not Work AFTER HU Installation
Old 04-21-2009, 06:32 PM
6th Gear
prothanh4's Avatar
So a HU was installed in my car and now my instrument cluster lights as well as my dash lights do not work. All the fuses are good I checked panels as well as under the hood. I took apart the dash and found out that a wire harness was not used and the guys just cut and spliced all my wires. I narrowed it down and the LIGHTS ON SIGNAL and the DASH LIGHT BRIGHTNESS CONTROLLER needs to be connected to something and its not. So does anyone know what i should do??? ANY SUGGESTIONS is better than driving in the dark.
Old 04-21-2009, 06:37 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
It shoundt have to be connected. Sounds like something isnt connected correctly.
Old 04-21-2009, 06:46 PM
6th Gear
prothanh4's Avatar
but when i turned on the headlights there is power going to those wires and when the headlights are off those wires go to ground
Old 04-21-2009, 07:05 PM
juanclopez2786's Avatar
is the dimmer switch working? disconnect the dimmer switch, when your looking at the plug its a 6 pin connector 123456 check resistance between 4 and 5. it should be between 0-20k ohms when you adjust the knob.
Old 04-21-2009, 07:48 PM
6th Gear
prothanh4's Avatar
im really new when it comes to my TL but how am I suppose to do that
Old 04-21-2009, 09:15 PM
do you know how to use a digital volt ohm meter?
Old 04-21-2009, 10:34 PM
6th Gear
prothanh4's Avatar
yea, ok ill check that in the morning. hypothetically speaking what if it's not the dimmer switch where do i go from there. does it have anything to do with the LIGHTS ON SIGNAL and the DASH LIGHT BRIGHTNESS CONTROLLER wires?? they are getting power when the headlights are turned on and off when the headlights are off. should i just cap those off or are they suppose to be connect somewhere??
Old 04-22-2009, 06:35 AM
fsttyms1's Avatar
Those wires dont need to be connected. My lights worked when it was disconnected. I still think something is hooked up wrong. Who did the install? Id bring it back to them.
Old 04-22-2009, 10:41 AM
totaledTL's Avatar
^ Agree- why don't you take it back to the installer & ask them to recheck it if it worked before the installation?
Old 04-22-2009, 04:07 PM
6th Gear
prothanh4's Avatar
ok i took a voltmeter to the dimmer switch and its working fine. i checked all the wires and capped off those two wires. The lights worked fine before the HU. i'm kinda out of ideas.
mada51589
05-03-2022 08:54 PM
02-25-2020 09:57 AM
wusty23jd
09-24-2015 11:41 AM
drewdeezy03
09-03-2015 08:04 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
Quick Reply: Dash Lights Do Not Work AFTER HU Installation
